73 8.5 posi guts inside a 66 cutlass 8.2 rear ??
Old October 17th, 2013, 11:16 AM
eurojeff's Avatar
Got a deal on nice 8.5 10 bolt posi,3.73 but its a multi leaf. Need to find out if i can swap out 8.2 for 8.5 posi ,axles,etc. Any body been down this road??
eurojeff is offline
Old October 17th, 2013, 12:27 PM
507OLDS's Avatar
If you are talking about swapping the guts from the 8.5 into the 8.2,no you can not.
What car do you have?
507OLDS is offline
Old October 17th, 2013, 01:35 PM
eurojeff's Avatar
66 cutlass with a 200 R4
i thought the 66 & up had the wider rear
eurojeff is offline
Old October 17th, 2013, 01:42 PM
car guy
gearheads78's Avatar
The 72 Cutlass axle I used on my old 66 was the same width as the 8.2 I pulled out. If you want to run a 8.5 thats what you need. I leafspring rear will not work because there is no upper control arm mounts.
gearheads78 is offline
Old October 29th, 2013, 05:34 AM
eurojeff's Avatar
I found another complete 10 bolt 3.73 rear from a 73 with aftermarket links,springs,etc. Whats the difference in the earlier 8.2?
eurojeff is offline
Old October 29th, 2013, 06:08 AM
car guy
73-77 will not interchange with a 64-72
Old October 29th, 2013, 06:18 AM
eurojeff's Avatar
Whats the is fitting problem,is it mounts,length,whats the big hurdle?
eurojeff is offline
Old October 29th, 2013, 06:30 AM
car guy
All of it. Control arm points, spring location its all redesigned in 73. There are way too many 68-72 A-body rear axles around than to try to custom mount a 73-77 axle.
PS you sure the axle you are looking at is from a 73? There are very few companies that make anything aftermarket for a 73-77 a-body
Old October 29th, 2013, 07:06 AM
eurojeff's Avatar
well i bought it already for 200,so its just another lesson learned. i guess i'll see if i can trade it for a 72 an earlier.
eurojeff is offline
Old October 29th, 2013, 07:07 AM
eurojeff's Avatar
Came out of a 73 GTO as the story goes
eurojeff is offline
65Gutless
June 9th, 2015 11:25 PM
jensenracing77
September 9th, 2009 06:12 PM
Meat10
September 16th, 2008 06:59 AM
Meat10
August 28th, 2008 04:14 AM
Meat10
August 8th, 2008 12:58 PM
Quick Reply: 73 8.5 posi guts inside a 66 cutlass 8.2 rear ??
