73 8.5 posi guts inside a 66 cutlass 8.2 rear ??
Old Oct 17, 2013 | 11:16 AM
eurojeff's Avatar
Got a deal on nice 8.5 10 bolt posi,3.73 but its a multi leaf. Need to find out if i can swap out 8.2 for 8.5 posi ,axles,etc. Any body been down this road??
Old Oct 17, 2013 | 12:27 PM
507OLDS's Avatar
If you are talking about swapping the guts from the 8.5 into the 8.2,no you can not.
What car do you have?
Old Oct 17, 2013 | 01:35 PM
eurojeff's Avatar
66 cutlass with a 200 R4
i thought the 66 & up had the wider rear
Old Oct 17, 2013 | 01:42 PM
gearheads78's Avatar
car guy
The 72 Cutlass axle I used on my old 66 was the same width as the 8.2 I pulled out. If you want to run a 8.5 thats what you need. I leafspring rear will not work because there is no upper control arm mounts.
Old Oct 29, 2013 | 05:34 AM
eurojeff's Avatar
I found another complete 10 bolt 3.73 rear from a 73 with aftermarket links,springs,etc. Whats the difference in the earlier 8.2?
Old Oct 29, 2013 | 06:08 AM
car guy
73-77 will not interchange with a 64-72
Old Oct 29, 2013 | 06:18 AM
eurojeff's Avatar
Whats the is fitting problem,is it mounts,length,whats the big hurdle?
Old Oct 29, 2013 | 06:30 AM
car guy
All of it. Control arm points, spring location its all redesigned in 73. There are way too many 68-72 A-body rear axles around than to try to custom mount a 73-77 axle.
PS you sure the axle you are looking at is from a 73? There are very few companies that make anything aftermarket for a 73-77 a-body
Old Oct 29, 2013 | 07:06 AM
eurojeff's Avatar
well i bought it already for 200,so its just another lesson learned. i guess i'll see if i can trade it for a 72 an earlier.
Old Oct 29, 2013 | 07:07 AM
eurojeff's Avatar
Came out of a 73 GTO as the story goes
65Gutless
Jun 9, 2015 11:25 PM
jensenracing77
Sep 9, 2009 06:12 PM
Meat10
Sep 16, 2008 06:59 AM
Meat10
Aug 28, 2008 04:14 AM
Meat10
Aug 8, 2008 12:58 PM
