Any other posi options,68-72
Old Jul 23, 2012 | 06:36 PM
Nasty455's Avatar
XCELERATIONRULES!
Having a hard time finding a reasonable deal on a posi rear for my 71 cutlass.
Found a 66 reasonably priced,but owner states the 66 is 1 inch shorter.
Does everything else line up correctly?
Any other easy options for a posi?
Thanks.
Old Jul 23, 2012 | 06:42 PM
ah64pilot's Avatar
Can you not build the corporate 10 bolt that's in it?
Old Jul 23, 2012 | 06:56 PM
Nasty455's Avatar
XCELERATIONRULES!
Long story.
I bought a project with a incorrect rear end,and pulled the open rear from my cutlass for that project.
I now want to upgrade to a posi,but have no carrier.
Thanks.
Old Jul 23, 2012 | 07:02 PM
ah64pilot's Avatar
I would put out a wanted ad, if you can get a '71-'72 10 bolt for cheap you can put an auburn posi and gears in it for less than $1000. Mine is holding up just fine, and it was built in 1998.
I know Brian Trick (507olds) builds rears as well...although that may be over your budget.
Old Jul 24, 2012 | 05:00 AM
507OLDS's Avatar
There is an abundance of posi units & gears for the 71-up 8.5" 10-bolt.Your 71 Cutlass came with one of those rears originally,and that sounds like what you are trying to build.
Old Jul 25, 2012 | 07:49 PM
Nasty455's Avatar
XCELERATIONRULES!
8.5 would be great..The problem I'm having is finding one at a decent price.
I've recently lost my job,and the car is on stands in the garage.
My drop top is sitting in the elements,and having a car without wheels is really bumming me out...
Old Jul 25, 2012 | 09:08 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have a posi unit from an 89 wagon with the tow package here that I could pull apart and get you a fair price on. It would be an auburn cone type and not the trac lock style though. I don't remember if it was a 3.08 or a 2.73. I'd have to pull it apart and check. Let us know what the budget is, and we can help within reason. I also have a good set of 3.08 gears here.
Old Jul 26, 2012 | 04:36 AM
507OLDS's Avatar
J- That posi unit is 30-spline,and he needs a 28-spline.
costpenn
Sep 20, 2014 06:21 AM
Guitar40
Jul 15, 2012 10:02 PM
Jul 5, 2012 09:34 AM
RAMBOW
Mar 23, 2009 02:05 PM
flatoz
Jan 28, 2009 11:37 AM
