Drive shaft O-axle Olds 442 1968
Old February 17th, 2012, 11:42 AM
starfire_62's Avatar
Hi
I am looking for axle shafts for my Oldsmobile 442 1968. There is an axle called the O-axle on the vehicle and I am in need of new axle shafts. There are no C-clips on this axle and itīs 28 splines, I had tried a chevy axle but it didnīt fit. I hope you can help me with this.
Looking forward for a positive answer.
starfire_62 is offline
Old February 17th, 2012, 04:46 PM
monzaz's Avatar
Axle shafts
I have what you need. Used or NEW sealed bearings
Just PM me and will get you taken care of. Jim
If you have it out already send pictures to us and will be sure the type of bearings and seals your using...A 68 SHOULD be using a sealed bearing with a seal inside the axle tube .
Jim
J D
330 659 7117
monzaz is offline
Old February 17th, 2012, 11:52 PM
The drive shafts are out of the axle, will try to send You some pics!
Old February 18th, 2012, 12:30 PM
4rims's Avatar
I have one side only if that wiil help. I had to buy a whole rear end because one of me bearings tore one axel up. it is a 28 spline,O for a 1968 Cutlass
Dave
4rims is offline
C.oleson
February 17th, 2014 04:29 PM
Hank
May 17th, 2013 04:51 PM
miko442
January 3rd, 2013 02:11 PM
Hairy Olds
December 26th, 2012 11:30 AM
bobfo1
Drivetrain/Differentials
July 14th, 2011 09:13 AM
Quick Reply: Drive shaft O-axle Olds 442 1968
