Drive shaft O-axle Olds 442 1968
Hi
I am looking for axle shafts for my Oldsmobile 442 1968. There is an axle called the O-axle on the vehicle and I am in need of new axle shafts. There are no C-clips on this axle and itīs 28 splines, I had tried a chevy axle but it didnīt fit. I hope you can help me with this.
Looking forward for a positive answer.
Axle shafts
I have what you need. Used or NEW sealed bearings
Just PM me and will get you taken care of. Jim
If you have it out already send pictures to us and will be sure the type of bearings and seals your using...A 68 SHOULD be using a sealed bearing with a seal inside the axle tube .
Jim
J D
330 659 7117
Jim
J D
330 659 7117
