gm 8.5 rear end
Old July 7th, 2011, 06:36 PM
73olds350r's Avatar
gm 8.5 rear end
I found a 1983 buick regal t type with the 8.5 it has the 3.42 gear it is open
I was wondering what a good price is to offer?
Thanks kris
73olds350r is offline
Old July 7th, 2011, 07:07 PM
Redog's Avatar
$200 with or without the brakes.
Take the cover off and turn the axle BEFORE you buy it, make sure all the teeth are there. You're probably going to want to replace the fluid anyway if it's still there. See if it looks clean and is not burnt
Redog is offline
Old July 7th, 2011, 07:23 PM
73olds350r's Avatar
Yea its got brakes swaybar drive shaft....Im going to be the one taking it out of the car ... Thanks for the info I will be puting a posi in it when I get to that point later down the road.
Kris
Old July 8th, 2011, 06:51 AM
507OLDS's Avatar
Something like that usually goes for $700.00,for a non-posi.It's more if it has a posi.The G-body 8.5" housings are fairly valuable.Just make sure it's an 8.5" and not a 7.5".If it is an 8.5" get the drivehshaft as you mentioned.
507OLDS is offline
Old July 8th, 2011, 11:40 AM
Before you hand over any money, be ABSOLUTELY SURE it's an 8.5. Buick did not start using the 8.5 in the G-body cars until the 1985 model year, so if it really is an 8.5, it's been swapped in. Also verify that it really is a G-body axle and not an A-body axle that was forced into place.
joe_padavano is offline
Old July 8th, 2011, 01:36 PM
73olds350r's Avatar
I got all the RPO codes in hand and I seen the pic's of a 8.5 and can see the diffrents in the two. I did not know they started in 85 I have to ask about that he said he got a few other t type as well so who knows...... but thanks for the help guys
Old July 9th, 2011, 02:53 PM
73olds350r's Avatar
Well it turn out the one he was trying to sell me was a 7.5 the funny thing is there was another regal t type next to it with the 8.5 so went and got the guy and he was like o I did not know but of couse he would not sell me the right one.
I can stand people like that.
Old July 9th, 2011, 08:28 PM
507OLDS's Avatar
Knowledge is everything.
507OLDS is offline
Old July 11th, 2011, 02:20 PM
Not an Olds guy. Car guy
Project Grandpa's Avatar
I read the first two replies and the first thing that came into my head is that if you see an 83 TType with an 8.5, somebody put it there. 84 in the HO, 85 in the Buhog T cars. Oh well. But if you can score a peg leg polly for under $700 you are in good shape.
My 81 Bu has an 85 TType diff with a 79 Z28 center section and Strange 28 spline axles. Factory 3.73s out of a 76 TA and Frankenrear was born.I am sure it will have to break eventually, but it has survived exactly 121 10 second passes on drag radials.
Project Grandpa is offline
Old June 21st, 2014, 02:30 PM
MyFathersOldsmobile's Avatar
I have to question that that the first year was 85. My research shows 84.
1984 Buick Regal 8.5″ 3.42 Ratio axle
GTE
GTP (Posi)
6TJ
1985 Buick Regal 8.5″ 3.42 Ratio axle
8TJ
8TP (Posi)
1986 Buick Regal 8.5″ 3.42 Ratio axle
2TJ
8TP (Posi)
1987 Buick Regal 8.5″ 3.42 Ratio axle
2TJ
3TJ
2TP (Posi)
3TP (Posi)
MyFathersOldsmobile is offline
Old July 18th, 2014, 03:00 PM
TexasT's Avatar
X2 on Buick Turbo Regals having an 8.5 from 84-87.
GTE
GTP (Posi)
6TJ
8TJ
8TP (Posi)
2TJ
8TP (Posi)
2TJ
3TJ
2TP (Posi)
3TP (Posi)
TexasT is offline
Old July 18th, 2014, 05:02 PM
66400's Avatar
Last one I had was a 3:73 open from a 87 442 and took a couple of years to sell. Had maybe a couple of dozen potential buyers ask about it. Soon as I tell them it's non posi it's no sale! On the other hand I've had 3 with posi and never took more than a month or so to sell.
Henry
66400 is offline
Old April 28th, 2017, 11:50 PM
Birdman86's Avatar
Hi there
Birdman86 here I'm looking to buy a 8.5/3.42
For a g body.
Birdman86 is offline
Old April 29th, 2017, 03:44 PM
Olds Fever
CRUZN 66's Avatar
I would suggest you start a new thread of your own in the parts wanted section... You are tagging onto a thread where the last post is almost 3 years old and members may pass it by since it was actually started in 2011...
CRUZN 66 is offline
Old April 30th, 2017, 12:45 AM
Hookers under Hood
76olds's Avatar
X2 ang you could try the G-body forums, someone may have one for sale. They are getting harder to find these gays and are on the pricey side.
I agree with John on starting thread in parts wanted, someone may have one here.
Eric
76olds is offline
Old April 30th, 2017, 01:29 PM
monzaz's Avatar
I agree with this...1983 should not have a 8.5 10 bolt rear under it...it was a 7.5 from the factory. BE SURE your getting what you pay for.
DO not start the offer...If someone is selling it they should start the price. Jim
monzaz is offline
Old April 30th, 2017, 01:31 PM
monzaz's Avatar
10 bolt 8.5 GN 442 rear for sale
Henry
I will buy every non posi 10 bolt 8.5 GN rear you got 3.42 or 3.73
200-400 dollars.
Jim J D
monzaz is offline
350TurBRO
September 12th, 2014 11:52 AM
MDchanic
31
August 12th, 2012 04:24 AM
martine
Drivetrain/Differentials
16
September 13th, 2007 10:12 PM
<George>
July 12th, 2004 11:00 AM
crank.it
April 30th, 2003 07:01 AM
Quick Reply: gm 8.5 rear end
