Clunk when slow backing
Old May 27, 2026 | 06:44 PM
Redbud40's Avatar
I recently started hearing a clunk / pop when slowly backing and maneuvering into garage. When going into drive to align better also hear pretty loud pop..
Then again when back to reverse to enter garage. IOW hearing it when going back and forth between reverse and drive to manauever into garage.
Do not hear or feel anything similar driving down the road. ?
Mike
Old May 27, 2026 | 07:00 PM
Redbud40's Avatar
Forgot. 72 Cutlass Supreme 350. Mostly stock.
Old May 27, 2026 | 07:02 PM
First I'd check the ujoints, then suspension bushings.
Old May 27, 2026 | 07:29 PM
Yeah, my go-to check for u-joints is listen for a clunk when going between D and R.
Old May 27, 2026 | 07:40 PM
Redbud40's Avatar
Awesome. Thanks guys. I’ll check it out.
Old May 27, 2026 | 07:50 PM
If the clunk comes from front LH or RH side evaluate each ball joint.
Old May 28, 2026 | 05:25 AM
X3 on the u-joints. Have someone shift the car from D to R and back while you listen outside the car. If not the U-joints, the next most likely cause is excessive backlash in the rear axle pinion.
cmpcpro
Nov 28, 2016 10:18 PM
lemoldsnut
Dec 15, 2014 12:47 PM
rcdynamic88
Aug 29, 2013 12:46 PM
Joffroi
Jan 17, 2012 04:23 PM
navvet
Aug 22, 2011 03:57 PM
