Source of 2.56 - 2.78 ring and pinion gears for 1970 Cutlass
Old Sep 28, 2021 | 11:57 AM
70 w-30's Avatar
Old Olds Fanatic
I'm rebuilding the reared of a 1970 cutlass and am looking for new gears. The #673 housing is in great shape and I'd like to reuse it or find a new used #671 28 spline. I'm changing all the bearings seals and gears because the reared appears to have been run with very low oil level. The pinion backlash was .020.
Ya'll are gonna love this one. The oil fill plug was cracked and seized in the hole when I bought it, someone had drilled a hole in the cover to fill it and used a plastic plug to close the hole. Plastic not rubber and it didn't seal well! You could see the leakage on the cover. When I opened it up there was less than a quart of oil in it and a lot of very fine metal in the bottom. The posi plates are actually in good shape with lots of scalloping showing.
Any sources for gears or if some one has an old housing #671 they didn't use please let me know.
Thanks,
Ben
Old Sep 28, 2021 | 12:02 PM
Randy's Ring and Pinion in Washington State. They should have what you want.
Old Sep 28, 2021 | 12:08 PM
70 w-30's Avatar
Old Olds Fanatic
thanks!
Old Sep 28, 2021 | 12:24 PM
bccan's Avatar
I think I have a set 2.56 or 2.78 gears. If you’re ok with used gears you can have a set cheap. If interested, I just have to confirm I have them still stored in the attic.
Morten Kammer Soerensen
Mar 31, 2020 09:00 PM
GEARMAN69
Oct 6, 2015 11:10 AM
2w-30s
May 14, 2013 03:20 PM
goatwgn
Drivetrain/Differentials
Dec 28, 2012 08:28 AM
Indy_68_S
51
Jun 6, 2010 09:37 PM
