Having some trouble finding the right Posi
1970 Olds Cutlass Supreme
12 bolt cover
10 bolt carrier
8.5” gear
No clips on the axle
28 Spline
Stamped CFD8 and 402227 on the outer housing.
Gonna put 3.42 in it.
So to be forthright I’m a novice so most of this is out of my wheelhouse.
Summit says it should be 8.2 not 8.5 and there should be clips... so it must be some kind of an aftermarket non original swap etc
Local place says it should be a 10 bolt cover and they’re not sure either.
I’m pretty sure it’s the original axle but I’m kinda stuck on what posi to buy because no one can put me on the right part.
Maybe someone here can link me up to the right Posi and I can just order it and be done.
Any help is appreciated.
12 bolt cover
10 bolt carrier
8.5” gear
28 Spline
You have a 1970 O-Type rearend, which utilizes an 8.5" ring gear that is different than the 8.5" corporate 10 bolt.
The only posi carriers available for the O-Type are original GM or aftermarket Ford 8.8 carriers that are machined for the O-Type ring gear and to fit into the O-Type housing.
There are limited aftermarket gears for the O-Type as well - they ARE NOT the same as the 8.5" 10 bolt gears.
Supercars Unlimited is one source for the modified Ford 8.8 carriers:
https://www.supercarsunlimited.com/1...iers-i275.aspx
Jim at JD Race (goes by monzaz on Classicolds) may be able to help you as well with both gears and carrier:
http://www.jdrace.com/
Richmond Gear web catalog for the O-Type gears:
https://www.richmondgear.com/wp-cont...n1.pdf#page=32
Word of advice: The Summit catalog (and Jegs, and Rockauto) is NOT an authority on Oldsmobile cars and parts. Pretty much everything you see there assumes that every GM car on the road is a Chevy. If you search for parts for an Olds 350, you'll get parts for a Chevy 350. If you call their tech line and ask about a Type O axle, you'll get deer in the headlights.
Best way to go. Summit does carry one, Jim probably is cheaper. I would like to run a 80W140 synthetic, so when I want to do my gear swap, I may see if he can do a Trutrac posi.
Natedawg
Drivetrain/Differentials
Apr 10, 2019 12:35 PM
