chevelle axle shafts in my cutlass 10 bolt?
Wow, I attempted to do research on the different gm diffs out there and there are a ton of variables. I am hoping that someone can help me shed some light on compatibility. My 71 cutlass has the stock open 8.5" 10 bolt rear end and I would like to put a posi unit in there. I have a 30 spline 10 bolt posi unit and an opportunity to obtain 30 spline axle shafts from a 70 chevelle 12 bolt. I was under the impression that 30 spline axles will work in the 10 bolt diff but I don't know enough of all the differences to know if the chevelle axle shafts are a direct swap. I realize I will need to replace the seals and bearings. Thoughts?
That is good thinking on your part.I.If he has the gov-lok unit,the GM special tool to disassemble those units is around $300,so you would have to be able to do a bunch of these units to make it worthwhile.Also that tool is ring gear diameter specific,meaning different tool for 7.5 8.5 9.5 10.5 units.To be honest with you I hate these units as much as I hate auburn units .I don't use either of these units,as I mostly do Muscle car & performance rears.Tom from Tom's differentials used to sell me 8.5 Eaton posi's and a set of 12 bolt Eaton side gears.I would disassemble the posi unit and install the 12 bolt side gears.While It's apart,I would blueprint the clutch stacks with a differential of no more than .001".Now you have a 10 bolt rear that is as strong as a 12 bolt rear.Unfortunately Tom is now gone.He was an infinite wealth of info on rearends.His slogan is (Home of made in the USA).Quality man,Quality parts.Most rearend parts are now South Korea & China made and I won't use it.Just so everyone knows,Tom's Differentials is still in business and online.It is being run by his Wife and family and are awesome people and great to do business with
