"Torsion tube" drive shaft
Old Oct 17, 2020 | 11:25 PM
delta7388's Avatar
Question "Torsion tube" drive shaft
tube inside a tube encased in rubber, damper effect? my '67 delta 88 has one and wondering which end the slip yoke is supposed to be on..........
Old Oct 18, 2020 | 04:15 AM
rob1960's Avatar
The slip yoke goes on the solid end, The "open"
end where you can see both the tubes & the rubber damper goes towards the rear.
Old Oct 18, 2020 | 05:29 AM
This is correct, and is also what is shown in the B/C-body PIM for 1967, but the driveshaft on my 67 Delta had the open end forward, and it still had the original U-joints with the molded plastic retainers.
Old Oct 18, 2020 | 01:04 PM
delta7388's Avatar
Cool '67 b-body prop shaft
Thank You,
the reason i was asking as I just had my drive line serviced and was told it should be reversed with the open end at the differential and closed/welded end at transmission, which they did and that it was originally opposite at the factory, what is right or does it matter? , looks better this way ........ Factory had damper/open end at transmission
70convert
Drivetrain/Differentials
Mar 7, 2019 02:12 PM
chadrickle
Apr 8, 2017 03:52 AM
johnnyjaws
Sep 4, 2014 12:07 PM
sacloc
Apr 2, 2013 03:34 AM
HotBoy RuNNA
Aug 5, 2011 12:28 PM
