69 type O bearing
Old Jun 14, 2020 | 06:39 AM
kevdog442's Avatar
Member
69 type O bearing
If I pull the axle, should the bearing come out with the axle? Or is it pressed in to the housing?
Old Jun 14, 2020 | 08:17 AM
monzaz's Avatar
On all O type you should have bearings pressed on to the axle shaft and the bearing comes out with the axle. THEY are not pressed into the housing - Bearings pressed into the housing end would be c-clip set up axle system.
Jim
JD
Old Jun 15, 2020 | 01:50 AM
kevdog442's Avatar
Member
Ok thanks, the bearing didn’t come out with the axle and I thought it should.
Old Jun 15, 2020 | 02:45 AM
JohnnyBs68S's Avatar
Are you sure you have a Type-O? Not only is the axle bearing pressed onto the axle, there is a retainer pressed on after it. I have a hard time believing that both the bearing and retainer didn't come out with the axle unless there is something seriously bad about that axle.
Old Jun 17, 2020 | 08:45 AM
monzaz's Avatar
pictures
Send some pictures of the rear cover and or axle shaft.
Old Jun 17, 2020 | 05:38 PM
kevdog442's Avatar
Member
Old Jun 17, 2020 | 06:47 PM
edzolz's Avatar
Looks like that rear has been submerged in salt water !!
Old Jun 17, 2020 | 07:41 PM
Yeah, I thought the same thing!
Old Jun 18, 2020 | 03:00 AM
kevdog442's Avatar
Member
Yeah lol, the bearing went out in my 3.08 so I went over to my small pile of 2.78s and found the worst one to pull an axle. I guess I’ll try another one.
Old Jun 18, 2020 | 10:07 AM
monzaz's Avatar
WOW....!!!! That is a sealed Bolt IN AXLE bearing and the axle did slip out of the bearing....LOL. WOW!!!!!!
NOT GOOD>
So you need to measure the axle and see if the surface lost diameter or the bearing did.... Usuually we see the axle shaft being the issue here ..... The surface is not all scared on the axle?
Check it out. Measure and see. 1.382 on the shaft I believe...Someone with book specs chime in here.
Old Jun 18, 2020 | 10:09 AM
monzaz's Avatar
Once you get the rear apart you can send a long steel or wood broom handle through the tube and hopefully knock out that bearing
Old Jun 18, 2020 | 04:20 PM
kevdog442's Avatar
Member
NOT GOOD>
Ok I’ll measure it, thanks for the help.
Old Jun 19, 2020 | 09:40 AM
monzaz's Avatar
If you have the proper puller obviously you can use that too. BUT I just try to give the back yard guy ways to do the job with out special tools for a one time deal.
Old Jun 21, 2020 | 08:01 AM
kevdog442's Avatar
Member
Ok so on the diff that the bearing went out of, the bearing came apart and I can’t find all of the ball bearings. Didn’t see them in the tube, pulled the cover not in there. Where’d they go? Can they even get into the gears?
442Harv
Drivetrain/Differentials
24
Feb 22, 2022 05:24 PM
slade69
Jan 16, 2020 03:35 PM
dc2x4drvr
Jul 12, 2018 11:39 AM
Classiccarjohn
May 18, 2010 09:49 AM
Bunser
Apr 21, 2008 03:12 AM
