Most common differential gear ratio
Old Oct 16, 2019 | 07:11 PM
rockdr's Avatar
What was the "standard," or most common, gear ratio in 1971 Cutlass Supremes? Is there any way to tell what gear ratio you have short of taking the diff cover off and counting the teeth on the ring and pinion?
Old Oct 16, 2019 | 07:57 PM
You can crawl under the car and find the differential code letters stamped on the right front inboard side of the axle housing tube. The first two letters designate the ratio code. The letters are ~1/4" high. You may have to wire brush the axle tube to remove the grime. Picture below is of mine. R2 = 2:56
I don't know the answer to your question regarding the standard or most common; but, I suspect a standard or most common gear ratio would be of the particular "SERIES" of vehicle. Once you find the differential code letters, post them and we can provide the differential gear ratio.
Mine is a 1971 CS Convertible sbo.
Old Oct 16, 2019 | 08:03 PM
Here is a post I created w/ several other members providing useful information regarding gear ratio which may assist you. I did the wheel rotation/drive shaft spin count to confirm the gear ratio.
71' CS SBO 350 Differential Confirmation
Old Oct 16, 2019 | 08:40 PM
rockdr's Avatar
Thanks. Next time I have the car on a lift I'll look for the code. Reading your reply and other responses I received, I'm pretty sure mine is also a 2.56:1, which is fine with me. My car is a standard run-of-the-mill '71 CS convertible, nothing fancy, but a very nice 75,000 mile survivor with no rust, no repairs and no dings.
Old Oct 17, 2019 | 01:40 AM
72455's Avatar
1972 U code Supreme
Sounds like a sweet ride..how 'bout some pics?😀
Old Oct 17, 2019 | 03:03 AM
69CSHC's Avatar
There are 14 variants of a 1971 Cutlass Supreme convertible.
Here are the standard rear gear ratios for each. From base version to top of the line SX.
1) 350 V-8 160-HP (man. 3) =============== 3.23 ( optional 2.73 and 3.08 )
2) 350 V-8 160-HP Turbo Hydra-Matic (aut. 3) == 2.56 ( optional 2.73 3.08 3.23 )
3) 350 V-8 180-HP (man. 3) =============== 3.23 ( optional 2.73 and 3.08 )
4) 350 V-8 180-HP 3-speed heavy duty (man. 3) = 3.23 ( optional 2.73 and 3.08 )
5) 350 V-8 180-HP 4-speed (man. 4) ========== 3.23 ( no optional gear )
6) 350 V-8 180-HP Turbo Hydra-Matic (aut. 3) ==== 2.56 ( optional 2.73 3.08 3.23 )
7) 350 V-8 200-HP Dual Exhaust (man. 3) ======= 3.23 ( optional 2.73 and 3.08 )
8) 350 V-8 200-HP Dual Exhaust 3-speed heavy duty (man. 3) = 3.23 ( optional 2.73 and 3.08 )
9) 350 V-8 200-HP Dual Exhaust 4-speed (man. 4) ========= 3.23 ( no optional gear )
10) 350 V-8 200-HP Dual Exhaust Turbo Hydra-Matic (aut. 3) == 2.56 ( optional 2.73 3.08 3.23 )
11) 350 V-8 200-HP G92 Axle Pkg (man. 3) ============= 3.42 ( no optional gear )
12) 350 V-8 200-HP G92 Axle Pkg 3-speed heavy duty (man. 3)= 3.42 ( no optional gear )
13) 350 V-8 200-HP G92 Axle Pkg 4-speed (man. 4)========= 3.42 ( no optional gear )
14) 455 V-8 250-HP Dual Exhaust Turbo Hydra-Matic (aut. 3) === 2.56 (optional 2.73 and 3.08 )
https://www.automobile-catalog.com/m...ible/1971.html
Old Oct 17, 2019 | 09:01 AM
My experience since around 1980 with my cars and friends cars is that 2.56 is the most common ratio as that was the standard, no cost ratio. Others were available as options at an additional cost.
Yes, you can use an online RPM calculator. Input the MPH, RPM, and tire height and it will give you the gear ratio.
You can also raise the rear tires off the ground (or just one with an open diff) with the trans in neutral, rotate the tire(s) and count the driveshaft revolutions. With the open diff, the turns will be off by a factor of 2 due to the differential action.
Old Oct 17, 2019 | 12:05 PM
rockdr's Avatar
My '71 CS, Sierra Copper repaint
Old Oct 17, 2019 | 12:47 PM
Some of the info from that automobile catalog website is incorrect, or at best confusing, which is why you should only use factory literature for info like this. Here's the actual factory information on standard and optional gear ratios with each engine and trans package in every Olds car line for 1971. The short answer is that with any engine, 2.56 was the standard ratio with AT and 3.23 was the standard ratio with MT. Of course, that means nothing since there were several optional ratios.
Old Oct 17, 2019 | 02:43 PM
Addressing your original question & a follow-up to Post #2, once you have determined the differential code letters stamped on the right front inboard side of the axle housing tube, look them up on the below chart (pg. 0-6; Fig. 10A - Differential Identification Code; 1971 Oldsmobile CSM).
Old Oct 17, 2019 | 09:01 PM
FYI, this is the code on my 1971 rear with 2.56 gears. Note that this rear has been wire brushed to remove rust, dirt, crud and has been painted. The stamping is difficult to see on a rear that hasn't been cleaned up.
Old Oct 18, 2019 | 10:53 AM
monzaz's Avatar
Well I have Parted out tons of Muscle car rears over the years and most common ratio I see is 2.56 and Chevy 2.73. That is just from thousands of rears in the Ohio area.
Remember most B O P vehicles had V8 power plants and that ratio was just the best for fuel mileage on a standard off the lot car.
Remember not all these cars were MUSCLE CARS - the were standard A-B cars drivers.
Jim
Billyaxe
Drivetrain/Differentials
Apr 30, 2021 02:35 PM
67Rocket
Jun 5, 2017 07:15 AM
quentinnw2
Dec 11, 2013 08:50 PM
1951Super
Apr 12, 2012 05:33 AM
Jharken
Feb 14, 2012 03:06 PM
