Rear Axle Bearings w a freezer, oven and a breaker bar
Old March 31st, 2017, 04:01 PM
shamusj's Avatar
Machine shops in my area were quoting $100-150 per axle to remove and press on axle bearings- this didn't include parts nor the removal of axles. Silicon Valley is starting to irritate me more every day.
I watched a ton of youtube videos and read postings here and the chevy world.
I took a risk and decided to do it the hill billy way (no offense to any hill billies on this forum):
1) Used cut off tool to cut outer race , peeled off bearings and then carefully cut into inner bearing sleeve and keeper. I cut about 3/4 of the way down and gave them both a gentle rap with a sharp chisel- no fight no swearing, both clicked and gave up the fight immediately.
2) Acetone clean up and steel wool on surfaces- everything looked great and clean.
3) A buddy had a set of bearings and seals from a never completed project- Timken seal and BCA bearings.
4) While the wife was out I slid the axle into the freezer for 2 hours then heated up the bearing and sleeve in oven to about 200 degrees.
5) Quickly grabbed axle, added a shot of wd40 and slid the bearing on. One gentle rap with a 4 foot section of 1.5" galvanized pipe and the bearing bottomed out perfectly.
6) I cranked the heat up to 400 degrees for the sleeve ( I heard they were a tighter fit)- slid it on a minute later and with 4 or 5 aggressive raps the sleeve was bottomed out.
Amazingly - I did not forget the retainer plate and I'm pretty sure all is good in the world.
Free parts, free labor and I can put it all back together this weekend.
Now....I'm wide open to hearing that my approach is bad. Not sure if this is an acceptable approach or wrong. Let me know either way.
Worst case - I pay the machine shop an arm and a leg to do it all over again.
shamusj is offline
Old March 31st, 2017, 04:40 PM
A perfect example of "necessity is the mother of invention". Absolutely nothing wrong with what you did.
oldcutlass is offline
Old March 31st, 2017, 05:21 PM
Sugar Bear's Avatar
An excellent solution that may be better versus a press as it put less stress on the bearing. Nice work!
Sugar Bear is online now
Old March 31st, 2017, 06:22 PM
shamusj's Avatar
Cool- for once my lame brain idea pans out.
Came damn close to forgetting the retainer plate..... this forum gave me many reminders.
shamusj is offline
Old March 31st, 2017, 09:25 PM
Junkman's Avatar
I am certain that his wife wouldn't agree with you, if she found out that he used her oven and freezer. She might even want them both replaced with new units, just on principle!!!
Junkman is offline
Old March 31st, 2017, 11:02 PM
Inline's Avatar
They are pretty tight fit, my hydraulic press was reading ~5,5 metric tons when the bearing&retainer bottomed.
Inline is offline
Old April 1st, 2017, 06:58 AM
Gary
VC455's Avatar
Nice work.
Your installation method is the same as they used in a milling plant I worked in. They couldn't freeze the 8" shaft but they heated the bearing in a 400° oil bath, used heavy gloves and slid it on the shaft.
Removal was easy too. The shaft was rifle drilled and cross-drilled in the bearing land area with a shallow groove under the inner race. Removal required a grease gun to inject grease between the land and the inner race. The grease pressure also caused the inner race to expand. One person could pull the massive bearing from the shaft.
VC455 is online now
Old April 1st, 2017, 07:50 AM
shamusj's Avatar
Coming together quicker than expected.....
shamusj is offline
Old April 1st, 2017, 07:55 AM
If those are 68 brakes, your missing parts, have wrong parts, and they are assembled wrong.
Old April 1st, 2017, 07:56 AM
And then there is this...
Old April 1st, 2017, 08:00 AM
shamusj's Avatar
Eric- thanks for calling that out. Kind of a funny story. A buddy came over last night after the kids went to sleep. We hadn't done a brake job on an old school car in 20 years. Beer courage was up so we dove in.
I was going to double check my work this weekend. I'd never drive on drunk brakes.
Would you be willing to share details of what parts are wrong and how my beer induced installation went south? My ears are wide open- Without this forum I'd be totally out of luck
shamusj is offline
Old April 1st, 2017, 08:10 AM
Your missing all the self adjuster parts and you have mostly wrong springs.. These are all the parts:
There are kits available, heres one from OPGI:
https://www.opgi.com/chevelle/MPA371/
Old April 1st, 2017, 08:33 AM
shamusj's Avatar
Fascinating. Some numb nut got in there before me. That teaches me for duplicating his work. Whats the saying - crap in, crap out.
I'm guessing the last brake guy was on shrooms when he did this one.
Thanks for the heads up. Much appreciated
shamusj is offline
Old April 1st, 2017, 08:39 AM
Rockauto has the drum brake self adjuster kit, $16.10 for R and L rear. The spring hardware kit combined $6.66. Both plus freight.
Old April 1st, 2017, 08:42 AM
shamusj's Avatar
Winner winner chicken dinner.
Love Rockauto - quick delivery, good quality and low prices.
Thanks again.
shamusj is offline
Old April 1st, 2017, 08:43 AM
Check your fronts, they may be screwed up also.
Old April 1st, 2017, 08:50 AM
shamusj's Avatar
Fronts are complete redo with modern discs- I'll check in when I get there.
You saved me a ton of money with the rock auto reference- I never thought they would carry detail parts like that.
shamusj is offline
Old April 1st, 2017, 08:51 AM
Junkman's Avatar
Thanks again.
Don't forget the Rock Auto 5% discount code... Just google it..
Junkman is offline
Old April 1st, 2017, 08:53 AM
shamusj's Avatar
Right on- Thanks.
Now the wife will be 5% less pissed off when she sees the credit card bill!
shamusj is offline
Old April 1st, 2017, 09:45 AM
monzaz's Avatar
brakes...
The biggest problem is the star adjuster spring rubs on the star and you do not have a auto arm adjuster as stated. Just get those left and right adjuster kits and a new hardware kit so you have all the correct parts. Jim
monzaz is offline
Old April 1st, 2017, 10:43 AM
Inline's Avatar
Right on- Thanks.
If there would be "like" button..
Inline is offline
Old April 1st, 2017, 11:21 AM
Those are basic parts the were used on just about every GM rear drum brake vehicle for, well almost forever, and as such are EXTREMELY common at auto parts houses.
Fun71 is offline
Old April 1st, 2017, 12:07 PM
m371961's Avatar
I picked one of these from the dumpster at work. Only needed some wiring to repair.http://www.industrial-toolcrib.com/B...FQ-GaQodqHYNgQ
m371961 is offline
Old April 1st, 2017, 12:40 PM
Now that's a cool dumpster dive find!
Fun71 is offline
Old April 1st, 2017, 02:35 PM
m371961's Avatar
Yea, if I was not so honest, the stuff they left abandon and unused in one shop I worked in would have been very handy. Everything from a 6 inch micrometer set to a Miller AC/DC TIG machine.
m371961 is offline
Koda
February 10th, 2017 01:38 PM
Oldssupreme
July 31st, 2014 07:58 PM
HWYSTR455
Drivetrain/Differentials
28
December 25th, 2011 11:55 AM
oldzy
September 14th, 2010 05:40 AM
1973olds98
September 24th, 2009 10:15 AM
Quick Reply: Rear Axle Bearings w a freezer, oven and a breaker bar
