Ring gear pattern
Old Apr 12, 2016 | 05:45 PM
1970_442's Avatar
Ring gear pattern
Can anyone tell me what they think of this pattern? These are used gears. this is the best that I've been able to get. not sure which way to move it from here or if i should move it. if i move any way even the slightest bit it seems to go way off. back lash is set to .007 right now i don't know what it originally was on these gears. pinion shim is set to .036.
Thank You
Any help would be appreciated.
Old Apr 12, 2016 | 05:56 PM
For used gears, the drive/coast patterns look really good. I doubt you're going to hear any noise out of them.
Old Apr 12, 2016 | 07:36 PM
Ozzie's Avatar
I agree. Your pattern looks good. In 1970 they were calling for .005" to .009" of backlash (at the tightest place) for new gears with no more than .002" variation around the ring. For used gears, I'd say you are about as tight as you can go. Clean it up; button it up; put some good lube and have some driving fun. It should serve you well.
Old Apr 13, 2016 | 08:10 AM
Run to Rund's Avatar
Run it!
Old Apr 13, 2016 | 08:13 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Ya good patterns! Hammer down!
Old Apr 13, 2016 | 01:51 PM
Chesrown 67 OAI's Avatar
Youve nailed it!
Old Apr 14, 2016 | 09:48 PM
monzaz's Avatar
gears
What ratio and what brand?
Old Apr 15, 2016 | 04:34 PM
1970_442's Avatar
Thank you everybody i appreciate it.
3.42 ratio. original GM gears.
oldspackrat
Aug 10, 2014 10:03 PM
junior supercar
Drivetrain/Differentials
74
Sep 13, 2013 01:17 PM
foo
22
Jun 23, 2013 12:30 AM
fabcraft
Nov 12, 2011 11:15 PM
idaholc
Apr 13, 2009 01:33 PM
