Sandblast the housing?
I have a '72 corporate Cutlass rear end. Has anyone sandblasted the differential housing without tearing it down? I'm fearful of getting sand in the housing regardless of how well I tape up the yoke and shaft seals. Recommendations?
If I do tear it down and replace the seals and bearings will it require all the set up of a ring/pinion change?
Thanks, Mike
Thanks, Mike
Thanks, Mike
Thanks, Mike
You should go ahead and change out the seals and wheel bearings while there, and see how your pinion seal is doing. (Use some NOS wheel bearings only and the 712146 seal - not the 2146 - ask me how I know) If it is weeping, you should change it as well, but you will need to go through the procedure to get the right torque on the nut afterwards to insure the unit begins to rotate at the proper level of driveshaft torque.
Here's a pic of my '70 installed - it was a rusty external mess but was in great internal shape.
Good luck!!
jeff sanford
September 10th, 2019 04:13 AM
