Where are the c-clips located and is there a trick in getting them out?
Old February 24th, 2014, 07:17 AM
71 cutlass convertible
lshlsh2's Avatar
I am taking apart a 89 trans am axle apart for some parts for a project? I have the diff cover off but cant figure out where the clips are or how to get them out? I'm sure when someone points it out I will feel stupid.
Larry
lshlsh2 is online now
Old February 24th, 2014, 07:43 AM
Professur's Avatar
Rotate the carrier. Push in the half shaft. Voila.
Professur is offline
Old February 24th, 2014, 09:21 AM
Oldsdruid
rocketraider's Avatar
And if you're very lucky that stupid pin won't break off in the carrier.
rocketraider is offline
Old February 24th, 2014, 09:36 AM
Octania's Avatar
that probably goes better after you remove the cross shaft which prevents the axles from moving inward.
Wait until you find out the bolt that holds the cross shaft in place is broken off down in there. Maybe that's just my luck, not others'.
Then w/o the cross shaft the gears it used to retain like to fall in/out and hamper your efforts.
Magnet on a stick helps retrieve the C clips.
Octania is offline
dave1978
January 9th, 2021 07:13 AM
Zrzoun
August 16th, 2015 08:45 AM
74hurstolds
May 6th, 2014 08:08 PM
Yukon
March 3rd, 2014 10:36 PM
Thuffner3
December 11th, 2007 07:38 PM
Quick Reply: Where are the c-clips located and is there a trick in getting them out?
