What is the significance of an "O" rear axle?
Old December 15th, 2018, 07:42 PM
72455's Avatar
I see a lot of chatter here on the forum about "O" rear axle assemblies, so I was wondering what is it about them that makes them so popular?
Dave
72455 is online now
Old December 15th, 2018, 08:08 PM
66-3X2 442's Avatar
Dave
First introduced in 66 and was carried thru 70. Some 66 & 67's had the 8.2 B/P 10 bolt instead of the 12 bolt O Type. All 68-70 Olds A-Body cars had the 12 bolt O Type rear axle. 66-69 had sealed axle bearings & 70 used the roller type axle bearings. They are not rare except for the lower geared posi units. To the purist,the O-type are desirable if their car came with one. They are hard to find parts for,especially gear sets and posi units. The 3.42/3.91 gears sets & a modified Phord 8.8 posi after market unit is about it for replacements. They have 12 bolt covers but have only 10 bolts holding the ring gear. Not really desirable for racing with slicks as they will not take a lot of continues punishment. Some will argue that but there's other rear axles that are much more desirable.
66-3X2 442 is offline
Old December 16th, 2018, 06:58 AM
To expand a little, the Type O is simply one of a number of different, unique rear axle assemblies used by various GM divisions in the 1960s. Most people are only familiar with the Chevy 10 bolt and 12 bolt axles and think that these are the only axles used by GM. That is not true. As noted above, Olds introduced the 8.5" Type O axle in May 1966 on the Cutlass line and used it through the 1970 model year. The Type O was ONLY used by Olds and only used on US-built cars (cars built on the Oshawa assembly line got the Chevy 12 bolt axle). To add to the confusion, Olds also used a 9.3" Type O axle on the full size cars from 1966-1970. This is completely different from the A-body axle and nothing interchanges.
The significance of the Type O is only that it was used exclusively by Olds and was the only axle used for the 1968-70 model years. Because of this, popularity is limited and aftermarket parts are nearly nonexistent. The A-body Type O has twelve bolts on the cover, so people assume it's a "12 bolt" axle, but the 8.5" ring gear only has ten bolts holding it to the carrier. The Chevy 12 bolt uses an 8.875" ring gear held to the carrier with twelve bolts. On big advantage of the Type O over the Chevy axles is that the axle shafts are retained into the housing with bolt-on plates that capture the pressed-on outer wheel bearings. This means that if you snap an axle shaft while racing, the rear wheel won't come off. This is a big step up over the Chevy axles that use C-clips to retain the axle shafts, and breaking a C-clip or snapping an axle can cause the rear tire and axle shaft to depart the car at the drag strip.
By the way, I'll add that despite only using ten bolts on the ring gear, the bolts on a Type O are larger in diameter than those used on a Chevy 12 bolt and can actually carry more torque before failure. Unfortunately, this is only one potential failure mode. The larger ring gear diameter on the Chevy axle does reduce contact pressure on the gear teeth, so in that case loads on the gear are lower.
joe_padavano is offline
Old December 16th, 2018, 07:19 AM
I vote sticky
Jamesbo is online now
Old December 16th, 2018, 07:35 AM
72 Olds CS
RetroRanger's Avatar
I'll add your 72 came w a 10 bolt " corporate" axle that has aftermarket gears and posi availible, as well as being plenty stout for most applications.
the 71-72 10 bolt has the same dimensions as the 68-70 a body o type and is often found as a replacement under those cars
RetroRanger is offline
Old December 16th, 2018, 09:29 AM
JohnnyBs68S's Avatar
Originally Posted by Jamesbo
I vote sticky
In that case, shouldn't someone mention that the A-body Type O also used two different axle splines depending on the gear ratio? IIRC, 28 spline axles were the most common and the higher gear ratios (3.91+?) used a 32 spline axle. Not sure if this was true for the larger 9.3" Type O, I suspect all those had a higher axle spline count.
JohnnyBs68S is offline
Old December 16th, 2018, 10:06 AM
66-3X2 442's Avatar
Only the 67/68 3.42 & lower geared O Types got the 31 spline axles. All the rest were 28 spline.
Old December 17th, 2018, 07:18 AM
oldsmobiledave's Avatar
exception
Your statement that ALL 1968-1969 Olds A body cars had the Type O is incorrect. The Oshawa Canada built 1968 and 1969 Olds A body cars used the Chevy 12 bolt exclusively.
oldsmobiledave is offline
Old December 17th, 2018, 07:49 AM
66-3X2 442's Avatar
I was talking American cars,not foreign cars. Besides,I said 68-70,not 68/69. Read for for comprehension,it's a wonderful thing. I think I've seen where you have misspoke a time or two or am I wrong?
Old December 17th, 2018, 08:06 AM
"All 68-70 Olds A-Body cars had the 12 bolt O Type rear axle". That is a direct quote from your post.
There is no mention of American built in your post and I am pretty sure that 68 and 69 are part of 1968-70 model run that you reference.
Many of the Oshawa built cars were sold into the US market as well as across Canada. Whether or not an Oshawa built car qualifies as a "foreign" car is debatable.
I point out that the 1968-1969 Oshawa built cars are an exception to your statement. This is just facts.
Old December 17th, 2018, 08:09 AM
66-3X2 442's Avatar
I see you don't have a sense of humor either. Lighten up,this ain't real life.
Old December 17th, 2018, 08:29 AM
delete
droptopron's Avatar
To get back on track, the only real significance to the Type O is its originality to the car. You can argue the pluses & minuses of the rear all day, but if you are building for performance there are better choices due to the previously mentioned lack of availability of parts.
If its a street car subject to normal driving it should be fine.
Worth a mention is the W27 Type O with an aluminum center section. Really rare and very expensive today.
droptopron is offline
Just the facts
You seem to have taken my post of facts as an insult when that was never the intention. It was just a statement of fact with no ill intent towards you. Apology if you were insulted.
Old December 17th, 2018, 09:00 AM
66-3X2 442's Avatar
No,you can't insult me and no apology needed either. Everything is cool on my end.
Old December 17th, 2018, 09:06 AM
Thanks for the correction, at least I got the 28 part right.
Old December 17th, 2020, 09:55 AM
fiebs442's Avatar
Can anyone tell me if there is an aftermarket posi for a 1969 442 "O" type with 3.23 gear ratio? I am looking at one that is GM 8.5" 10 Bolt / Posi / 28 Spline / Limited Slip. It can be seen at:
https://www.quickperformance.com/GM-...p_p_20348.html
fiebs442 is offline
Old December 17th, 2020, 10:09 AM
There is no aftermarket anti-spin carrier for the Type O. The market isn't big enough to be profitable. The corporate 8.5" parts won't work - the two axles have nothing in common. Some vendors modify a Ford 8.8 carrier to fit in the Type O housing.
Old December 17th, 2020, 10:21 AM
I installed a Nitro Gear and Axle Lunchbox Locker in my type O purchased through member Monzaz to give me an inexpensive posi. Outside of hearing some ratcheting when turning it works extremely well.
This winters project, rear suspension and locker install - ClassicOldsmobile.com
oldcutlass is online now
Old December 17th, 2020, 01:00 PM
fiebs442's Avatar
Thanks for the replies. Doesn't sound like there are too many options. I will have to consider the lunchbox solution.
fiebs442 is offline
Old December 17th, 2020, 01:14 PM
Yellowstatue's Avatar
The vast majority of A body '68's assembled in Oshawa had Chev 12 bolt axles, however those with 3:42 and 3:91 axles had Olds axles.
Yellowstatue is offline
Old December 17th, 2020, 01:48 PM
Eric
ecwieder's Avatar
I've had this on my wishlist.
https://www.supercarsunlimited.com/6...ier-d1938.aspx
It seems to address the O posi carrier question. No? Have not called the place to ask yet.
I've currently got a code "SE" which is 3.23 open.
Eric
ecwieder is offline
Old December 17th, 2020, 01:53 PM
fiebs442's Avatar
Eric, See Joe's post above. I also found other posts that seem to indicate none of those work. I am contacting monzoz to see if he can help me. You may want to consider him as well.
Mark
fiebs442 is offline
Old December 17th, 2020, 01:58 PM
Eric
I believe the Supercars carrier is one of the modified Ford 8.8" units.
Old December 17th, 2020, 02:45 PM
Randy C.
rcorrigan5's Avatar
I used the Supercars version to change the 3.23:1 open differential (S6 with the disc brakes) on my '69 4-4-2 convertible to a 3.23:1 anti-spin and it works fine. However, if I had it to do again, I would just leave it as an open axle. I don't race or do anything radical so the open differential would really have been just fine for me.
Randy C.
rcorrigan5 is offline
Old December 17th, 2020, 03:13 PM
Eric
ecwieder's Avatar
Good to know it works Randy. I haven't done the conversion yet for the same reasons you stated. It would make car show exit burnouts cooler though
Eric
ecwieder is offline
Old December 17th, 2020, 03:24 PM
briane's Avatar
I haven't done the homework so perhaps someone here can enlighten me. What is the difference between the '71-2 Corporate 10-bolt and the Chevrolet 10-bolt?
briane is offline
Old December 17th, 2020, 03:42 PM
The main difference is the 71-72 Olds (and Buick) rear has bolt in axles and does not use a c-clip retainer.
Fun71 is offline
Old December 17th, 2020, 06:06 PM
Aside from the axle retention, there is no difference. You can use the traditional 8.5" ten bolt Chevy carriers and gears in the 71-72 Olds axle. Just ignore the lack of C-clips.
August 6th, 2018 10:54 PM
sammicurr86
Drivetrain/Differentials
July 15th, 2017 07:44 AM
knighthawk
September 19th, 2014 11:49 AM
<powers455>
September 13th, 2007 09:11 PM
scrappie
April 8th, 2007 06:38 PM
Quick Reply: What is the significance of an "O" rear axle?
