What rear end is this?
Old Feb 3, 2013 | 12:39 PM
67 black goat's Avatar
I couldn't find a part #. Where is it?
Date code of G284
There is an N signifying nodular.
The strenghtening ribs on the front side seem to look like a Pontiac.
Ring gear is a 2.93
The shock mounts are in front of the axle.
55 1/2" between flanges.
Upper and lower control arms bolt in.
Measurements seem to match A-body rears.
Thanks for any help.
Old Feb 3, 2013 | 01:50 PM
m455sx's Avatar
Olds Nut
im attaching myself to thread to find out the answer
Old Feb 5, 2013 | 06:20 AM
66 POST's Avatar
GM rear
Looks like 8.5 GM rear, have seen a lot of them in 73-77 Cutlass 77 up full size before ft. wheel drive. Common in all other GM's of this period. Seen them with and without c clip axles. This one has pressed on axle brgs. --- notice no c clip buttons on axle ends and studs at backing plates , c clips would have nuts. Very good rear with spool and axles and lots of ratios available.
350TurBRO
Sep 12, 2014 11:52 AM
MDchanic
31
Aug 12, 2012 04:24 AM
martine
Drivetrain/Differentials
16
Sep 13, 2007 10:12 PM
<George>
Jul 12, 2004 11:00 AM
crank.it
Apr 30, 2003 07:01 AM
