T.A Performance Rear end Girdles..
Old Jun 2, 2012 | 05:10 PM
Stevec's Avatar
Has anyone used T.A Performance rear end girdle/diff cover? Just wondering if they are worth the $$.
Thanks.
Old Jun 2, 2012 | 05:39 PM
1965cutlassragtop's Avatar
I was checking those out too, they seem like solid covers. $159 on eBay with hardware & gasket. Supposedly the added support on the main bearing caps helps strengthen the rear end. I like the look of them too.
Old Jun 2, 2012 | 06:02 PM
Stevec's Avatar
Yeah they do look like a quality piece I might go for it at this point what's another $160.
I think it would look kinda tough back there too.
Old Jun 2, 2012 | 06:13 PM
Rickman48's Avatar
Can't hurt, if installed right!
Old Jun 3, 2012 | 05:58 PM
It's on of those "add it to the list" type of deals, haha. I think it's a worthy modification. Love the look of the beefy differential cover from behind the car.
Old Jun 9, 2012 | 08:55 AM
monzaz's Avatar
T/A covers
T/A has the thickest cover of most all of the aftermarket girdle cover. Most other knock offs are 1/2 the thickness and really do not do what they are suppose to.
The girdle cover is to stop cap deflection of the carrier when the ring and pinion a slammed hard off the line. THE THICJKER THER BETTER on these covers ...
T/A is the thickest.
There are companies that USE T/A to build there covers and then put there name on it Nitro gear and axle being one of them. I sell these Nitro covers 149.00
They EXACT as t/a but say Nitro gear and axle instead of T/A.
Jim
JD
Old Oct 18, 2012 | 01:01 PM
jfb's Avatar
jfb
They are worth the money for extra strength. I use mine to pre load for nitrous shock. The caps have a way of moving upon engagement. This is also a way to prevent movement for serious torque issues.
Old Oct 18, 2012 | 01:25 PM
gregvm's Avatar
I've been running one on my 12 bolt Chebby axle for over 25 years now....never an axle problem....even with slicks, manual trans, and 4.11's.
Just took it apart 3 years ago to drop down to 3.73's to help fuel economy, with a tremec overdrive tranny....NO sign of bearing fatigue or cap deflection. For $160, cheap insurance, plus it has a plug to check oil level, and the aluminum helps keep it cool on those long trips as well.
Old Oct 18, 2012 | 02:31 PM
oldsmobiledave's Avatar
me too
I have had one on the Chevy 12 bolt in my race car for 7 years. Never a drop of fluid leaking from the cover. The piece is worth the cost for the addded strength & looks. The thick casting is impressive.
350TurBRO
Sep 12, 2014 11:52 AM
Magna86
Jun 4, 2014 10:16 PM
MDchanic
31
Aug 12, 2012 04:24 AM
wmachine
Dec 30, 2009 05:55 AM
<Rocket Power>
Dec 8, 2004 05:44 AM
