Stripped oil fill plug
Old October 5th, 2019 | 05:34 PM
scrappie's Avatar
I have a 50 year old Olds rear end and the oil fill plug is stripped. It is the 3/8 square size hole that is a bit rounded. Any ideas on how to get it out so I can replace it? I was thinking of welding a 3/8 adapter in but I believe the diff is cast correct? I know the tubes are steel but not sure about the differential? Any ideas?
Old October 5th, 2019 | 05:51 PM
Sugar Bear's Avatar
Try epoxying the bit into the plug, let it dry for a couple of days and try to remove it if it cannot be welded to.
Good luck!!!
Old October 5th, 2019 | 06:04 PM
Schurkey's Avatar
Differential case is cast iron. The plug will be steel.
I just did this on a transfer case less than a week ago. Some moron rounded-out the 10mm hex Allen recess by--probably--trying to use a worn-out 3/8 Allen socket. I had to weld a bolt to the recess in the plug, and then wrench on the bolt head to unscrew it.
I've become very fond of installing brass plugs where the steel plug used to be--but brass doesn't grow on trees, and anyway my transfer case plug is metric--it's hard enough finding the proper metric plug in steel never mind trying to get one in brass.
Old October 5th, 2019 | 07:17 PM
scrappie's Avatar
Thanks for that! I was thinking ever since I posted and I thought the same thing about the plug itself being steel and weldable, you confirm that and I will try welding a short fat bolt in there and see what happens.
simonb.
April 5th, 2020 03:29 PM
Olds Scott
August 25th, 2013 10:00 AM
brandon 455
July 14th, 2013 01:53 PM
chasman414
May 21st, 2012 11:58 AM
Oldsfan
August 1st, 2007 10:40 AM
