rear end swap
Old Jul 15, 2009 | 11:07 AM
scrappie's Avatar
rear end swap
Will a 71 vista cruiser posi rear end bolt into a 68-69 442 with no problem?
The shock mounts look a little different.
Can you take all the internals from the vista rear and swap into an A body rear? I have two rears: one is open with 10-bolt cover and the other is the posi from the vista with 10-bolt cover. Can I swap gears if the rear doesn't swap phisically due to different shock mounts?
Old Jul 22, 2009 | 01:51 PM
1964f-85's Avatar
I ran a 73 vista cruiser rear end in my 64 and 72 cutlass and it fit fine, I see no reason it wont work in reverse. Remember to keep the old Vista drum brakes, they are wider that the regular cutlass'
Old Jul 25, 2009 | 06:55 PM
monzaz's Avatar
VISTA CRUISER REAR
Yes all 1965-1972 A-body sedan coupe convertible AND a-body wagons are all interchangeable housings...The internals may vary so keep them whole for less headache there. Jim
350TurBRO
Sep 12, 2014 11:52 AM
oldjunk
Apr 26, 2009 10:26 PM
olds cutlass
Drivetrain/Differentials
Apr 9, 2009 05:44 PM
loosecannon39
Feb 13, 2009 03:34 AM
sscutlas
Sep 4, 2007 10:20 PM
