Rear end change gear?
Old Aug 4, 2013 | 11:28 AM
sammieolds's Avatar
Hi all I wanted your guy's advice I have a eaton r end w/390 gears
Would changing them to 332? would that help the gas mileage I get between 8 & 10 MPG with a 400 and a/c stick when I'm in 4th it feels like it could use a couple more shifts like a 5 or 6 speed Any thoughts on this.
Thank's Steve
Old Aug 4, 2013 | 12:05 PM
Thank's Steve
Keep the 3.90 gears, get an O.D. trans. One less expensive option is the A833 OD four speed. This Chyrsler trans was used in Chevy pickups in the mid-80s so can be found with a GM bolt pattern and input shaft. A TKO is a better, if far more expensive solution.
Old Aug 10, 2013 | 01:36 PM
sammieolds's Avatar
Joe I Don't want to change the tranny because of the counsel
I rather chage the gears if it cheaper I'm thinking of getting a diff car this is to much for me w/ the clutch and stuff health issues but if I keep it I like to change the rear end gear if it help the gas mileage,what do you think Thanks Steve
I liked the 70-72 Cutlass w/350 rocket nice car
Old Aug 10, 2013 | 02:23 PM
oldstata's Avatar
Justin
What rear end do you have I am sure if you really want a change some one would love the 390 gears
If you don't want to swap the trans gears would help but it won't feel the same
Old Aug 10, 2013 | 02:37 PM
sammieolds's Avatar
It a eaton 390 I was thinking of keeping them and sell them w/the car
350TurBRO
Sep 12, 2014 11:52 AM
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
71 delta88guy
Oct 29, 2009 07:14 AM
Flye
May 23, 2009 06:58 AM
