Rear axle tube spring perch
Old Apr 12, 2019 | 02:14 PM
scrappie's Avatar
Does anyone sell the spring perch that is welded on the axle tube for 70 Gm A-body (Olds)?
Old Apr 12, 2019 | 03:10 PM
Currie enterprises or any of the aftermarket axle manufacturers do. You can ask monzaz also.
Old Apr 12, 2019 | 03:11 PM
scrappie's Avatar
Thx Eric
Old Apr 12, 2019 | 09:11 PM
monzaz's Avatar
They will not look the same as GM original. If you show a picture of it (as there are 3-4 different designs gm used for the 1967 -1972 era. BOP usually used a Open style...Some pontiacs had a semi closed like the chevy but a bit more. Then there is the chevy semi close cup.
I might have one from a sacrifice rear.
Jim
Old Apr 13, 2019 | 07:08 PM
scrappie's Avatar
Ill get a better close up but here is the rear. I just may need one?
Old Apr 14, 2019 | 03:36 PM
monzaz's Avatar
spring perch
Pretty much the standard BOP late model perch. I will look.
I really do not see the rust?
cletusvandamme
Drivetrain/Differentials
28
May 18, 2014 07:51 PM
amermuscle1
Sep 24, 2011 10:53 AM
panos
Jan 19, 2010 05:30 AM
onetogofast
May 4, 2009 04:57 PM
J-(Chicago)
Feb 23, 2008 09:54 PM
