Rear axle
Old Jan 12, 2010 | 04:27 AM
panos's Avatar
Rear axle
Is anybody who can help me dec.my rear axle?Dont even know if its an Olds,couldnt fint any number on the tubes but i found a num.on the right-front side of the carrier
Old Jan 12, 2010 | 07:12 AM
507OLDS's Avatar
That's an 8.2" 10-bolt,which is what came in that car originally.You will either need to find the stamped code,or pull the cover,to find out exactly what ratio you have.The stamped code should be on the passenger side axle tube,between the spring perch & the pumpkin.That general area.
Old Jan 12, 2010 | 08:20 AM
panos's Avatar
just went to the garage and took away all the color-dirt of trhe RH tube to the bare metal nothing?!
except the letters DS upside-down on the backside of the RH axle tube The car was manual before i dont know if that helps+a pic.of the vin nr.
Old Jan 12, 2010 | 11:59 AM
507OLDS's Avatar
That IS the code you need.The "SD" is upside-down because they assembled the chassis upside-down,so the person stamped the tube in that position.
SD = 3:08 posi
Old Jan 12, 2010 | 12:09 PM
panos's Avatar
Ok thanks for the info,im just not that sure about the posi think,it spins only the right tyre when you do a burnout
Old Jan 12, 2010 | 02:53 PM
507OLDS's Avatar
Not sure without actually looking at it.A 3:08 non-posi would have a different code.A lot of things can happen in 40+ years. The posi unit might be worn,or maybe it was blown-up,& an open carrier installed in its place.Not sure.
Old Jan 12, 2010 | 03:02 PM
panos's Avatar
Ok Brian thanks for the info,any idea what ratios fits in those rear ends nr.of splines etc. BTW really sweat ride u have there
Old Jan 13, 2010 | 05:09 AM
507OLDS's Avatar
They make gears for that rear,& there are also some nice used one floating around. There are 3:23,3:36,3:55,3:90,etc.to name a few.
The axles have 28-spline,& the pinion stem has 27-spline.
Old Jan 16, 2010 | 06:35 AM
panos's Avatar
I open it up today and took a look inside the ring has 37 teeth and the pinion 11 teeth and its open,it comes up like 3:36?,did that ratio existed?
Old Jan 16, 2010 | 06:57 AM
70 cutlass s's Avatar
Old Jan 16, 2010 | 07:12 AM
panos's Avatar
OOOps missed it
Old Jan 16, 2010 | 11:53 AM
panos's Avatar
Does anyone used this? http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
I was thinking of ordering one,i know that they can sound a little but on the other hand they are easy to install.Any experiences with that thing?
Old Jan 17, 2010 | 06:30 PM
monzaz's Avatar
LSD vs locker units
The NO SLIP unit you linked to is great for LIGHT to LIGHT action and drag racing etc. For road driving in the hills and light wet surfaces they can become very treacherous...
The LSD (Auburn or Eaton) diff units are smoother transitions in the turns and more predictable in uncommon surfaces as water ice snow gravel etc. Plus still very good on the dry paved surfaces of course.
Jim
Old Jan 19, 2010 | 05:30 AM
507OLDS's Avatar
The Auburn unit should be fine for what you are doing,not to mention about $100.00 cheaper than that part you listed.Those units can be had for less money as well.
The Eatons are a bit more than the Auburns,but they are a nice unit,with clutches,& are rebuildable.
HitTheHole
Drivetrain/Differentials
Feb 4, 2021 10:46 AM
cutlasssupreme71
Feb 22, 2011 11:40 AM
dan1s
Sep 23, 2008 01:53 PM
dan1s
Mar 16, 2008 11:13 AM
<powers455>
Sep 13, 2007 09:11 PM
