1.37:1 rear gear ratio???
Old Apr 21, 2019 | 09:05 PM
Natedawg's Avatar
I have to be doing my math wrong. I rotated the driveshaft while I had my wife count the tire rotations. At 4 driveshaft rotations, my wife tells me that the tire rotated almost three times exactly. Knowing this did not sound right, I turned the driveshaft 8 times and the wheel went just over 5 and 3/4 around. I have yet to get this project car on the road for the first time since I purchased this car.
Old Apr 21, 2019 | 09:12 PM
Kyle's77cutlass's Avatar
Not a 1.73 but maybe 2.73
Old Apr 21, 2019 | 11:05 PM
hurst68olds's Avatar
only works with a "posi" & transmission in nuetral
1 rotation of the tire & count the driveshaft's revolutions
Old Apr 22, 2019 | 01:43 AM
svnt442's Avatar
If you are spinning only one tire you will only get half of the revolutions of the driveshaft due to the spider gears in the differential. That would net you a 2.73 gear ratio.
Old Apr 22, 2019 | 05:41 AM
bry593's Avatar
1968 442 Convertible
And it since it is half, it also means you have an open differential, no LSD.
Old Apr 22, 2019 | 01:24 PM
Or a limited slip with severely worn clutches.
Old Apr 23, 2019 | 08:19 AM
Lonnies Performance's Avatar
On a non-posi car, rotate the tire 2 turns while holding the other one from turning, & count the driveshaft revolutions to get the correct ratio.
Old Apr 26, 2019 | 09:14 PM
Natedawg's Avatar
You guys are awesome. You're right of course, I'm half off. That puts me at 2.73 gears thanks!
deejai35
Drivetrain/Differentials
Aug 11, 2015 05:42 PM
johnnyjaws
25
Aug 2, 2014 09:52 AM
Coltonis
Oct 27, 2009 10:15 AM
69-Sguy
Nov 19, 2007 07:56 AM
