rear ratio
Old Nov 18, 2007 | 01:34 PM
69-Sguy's Avatar
rear ratio
Odd question, maybe someone could help. I was trying to determine what gears I have (because I've got a real dog out the hole), so I used the tried and true method of jacking up the rear, marking both the driveshaft and the power tire (right rear). I spun the driveshaft by hand until (with help watching) I had the tire rotate 10 times, all the while counting my drivshaft rotations. It turned out to be 14 driveshaft rotations to 10 tire rotations. Could this be right, a 1.4:1 gearset? Anyone ever heard of this? It's a 69 Cutlass convert, and I'm almost positive the rear is origional. Did they even make a rear this low? If so, I guess I now know why I have no acceleration from a standstill. Thanks and Happy Holidays.
Old Nov 18, 2007 | 02:36 PM
Redog's Avatar
Is there an RPO code sheet on the trunk lid?
Probably a 2 series gear. I would guess 2.56 or 2.73
The code should be a GU code, and G80 which is a posi
Old Nov 18, 2007 | 08:54 PM
88 coupe's Avatar
Junior Member
Originally Posted by 69-Sguy
........ 14 driveshaft rotations to 10 tire rotations ........
If you had turned both tires (like when the car moves) you would have counted 28 driveshaft revs, or 28:1 = 2.8:1. You could have turned the single tire 20 (10 for each wheel) times, to get 28:10 = 2.8:1.
From where you are now, it's easier to multiply your 14 revs, by 2 to compensate for the missing 14 turns = 2.8:10 = 2.8:1.
........ Did they even make a rear this low? ........
In this context, 1.4:1 is a high gear. 6:1 is a low gear.
Norm
Old Nov 19, 2007 | 07:56 AM
sexycutlass69's Avatar
Smile
I'll hit you up on your PM!
sklbndt
Drivetrain/Differentials
23
Jun 3, 2009 11:59 AM
jonstringer
Oct 8, 2008 03:26 PM
Natas
May 22, 2007 08:50 AM
American Lead
Mar 31, 2007 04:37 AM
benkerr
Aug 26, 2006 07:41 PM
