proper driveshaft length
Old Oct 1, 2014 | 06:00 PM
1968_Post's Avatar
When I bought my '68 442, it had a 350 smogger motor and a turbo 350. I'm getting close to installing the 455 and a short shaft turbo 400. Now I'm wondering if the driveshaft may not be the original either. The shaft has a tube length of approximately 52.5 inches. Does anyone have the correct measurement?
Also, I moved the cross member to the furthest back position... is that correct?
Thanks...
Old Oct 2, 2014 | 07:27 AM
Yes you have to move the xmember to the rear approx. 6 inches. I like to measure the distance and have a driveshaft made for your mod. I separate the yoke, slip it into the trans, push it in all the way, then slide it back 3/4 of an inch. Then measure from the center of the Ujoint hole on the yoke to the center of the Ujoint on the rear end.
Old Oct 2, 2014 | 09:35 AM
Octania's Avatar
The factory service manual probably specifies the length for a 442, which SHOULD match what you are doing, but why not just do the above and get it right for sure? In case the rear end differs or whatnot.
I also recommend using center of u-joint to center of u-joint for the critical measurement. Any driveshaft shop can do you a nice new one easily. Be sure to note how the u-joint attaches at the rear end- c-clips inside the yoke probably. Measure the yoke recess diameter for the UJ caps and the distance from outside edges of c-clips, to ensure you get the correct U-joint and/or shaft aft end.
Old Oct 2, 2014 | 10:38 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Google Dennys Driveshaft dot com. Click in the upper left corner that says measurement. All the info you will need.
Old Oct 2, 2014 | 12:18 PM
I had the one made for my 67 after doing the same mod. A heavy duty steel drive shaft, balanced, assembled with new Ujoints, and my T400 yoke if I remember right was under $300.
Old Oct 2, 2014 | 12:31 PM
allyolds68's Avatar
x2
Then go to a local Fleet Pride and have them modify your driveshaft. It was a little over $100 for mine. I had to install new u-joints myself
Old Oct 2, 2014 | 05:18 PM
1968_Post's Avatar
Thanks for the replies...
texasred
Drivetrain/Differentials
Apr 27, 2012 07:28 PM
matviar
Feb 11, 2012 07:19 AM
texasred
Mar 14, 2011 07:42 AM
4-Speed
May 22, 2010 06:47 PM
ctrain22
Sep 8, 2009 12:15 AM
