Posi (limited slip) rear for a 1967 big Olds
Are posi rears available for 1967 Olds Delmont or Delta 88's? It's my understanding that these are tough to find. If so, are there any complete rear end assemblies that are easily fitted to this model?
I have a 1967 - Olds 98 rear end , it is a 2:73 posi complete with brake drums . It is in good condition , came out of a running car . I am asking $400 for it , i am located in northern Illinois , zip 60034 . Let me know if you can use it . thanks BOB .
You might want to check with this guy and see what rear is in the 67 Bonneville he's parting. He only wants $100 for the complete axle assembly:
http://forums.performanceyears.com/f...d.php?t=686255
Full size Olds
How many bolts on the rear diff cover?
The ratios for the full size Olds are very limited with the 12 bolt cover. 2.56 2.73 3.08
if you are lucky VERY LUCKY you can find 3.23 3.42 in a wagon.
The Bonneville that the guy on Performance years is a PONTIAC 10 bolt cover with 12 bolt guys and they do make 3.55 aftermarket gear for that rear. The posi units are a bit more easy to find too.
I have a 1968-1970 Bonneville / Catalina rear with the 3.55 gears and posi BUT not sure if the spring perch mounting and control arm mounting is the same? Need measurements and pictures to help you. Jim
J D
J D
Ctls442
August 7th, 2015 10:43 PM
Delmont 88 PA
Drivetrain/Differentials
July 24th, 2014 06:20 PM
1966Oldsmobile
November 24th, 2013 05:10 PM
