Posi (limited slip) rear for a 1967 big Olds
Old Mar 29, 2012 | 04:28 PM
Delmont 88 PA's Avatar
Are posi rears available for 1967 Olds Delmont or Delta 88's? It's my understanding that these are tough to find. If so, are there any complete rear end assemblies that are easily fitted to this model?
Old Mar 30, 2012 | 10:01 AM
Bob Kelso's Avatar
I have a 1967 - Olds 98 rear end , it is a 2:73 posi complete with brake drums . It is in good condition , came out of a running car . I am asking $400 for it , i am located in northern Illinois , zip 60034 . Let me know if you can use it . thanks BOB .
Old Mar 31, 2012 | 08:20 PM
copper128's Avatar
Lt. Buzzkill (ret.)
You might want to check with this guy and see what rear is in the 67 Bonneville he's parting. He only wants $100 for the complete axle assembly:
http://forums.performanceyears.com/f...d.php?t=686255
Old Apr 1, 2012 | 04:59 PM
Thanks for the responses!
Old Apr 5, 2012 | 09:13 PM
monzaz's Avatar
Full size Olds
How many bolts on the rear diff cover?
The ratios for the full size Olds are very limited with the 12 bolt cover. 2.56 2.73 3.08
if you are lucky VERY LUCKY you can find 3.23 3.42 in a wagon.
The Bonneville that the guy on Performance years is a PONTIAC 10 bolt cover with 12 bolt guys and they do make 3.55 aftermarket gear for that rear. The posi units are a bit more easy to find too.
I have a 1968-1970 Bonneville / Catalina rear with the 3.55 gears and posi BUT not sure if the spring perch mounting and control arm mounting is the same? Need measurements and pictures to help you. Jim
J D
Old Apr 10, 2012 | 04:31 PM
JD, thanks and I will compare the rears this weekend. Chris
Ctls442
Aug 7, 2015 09:43 PM
Delmont 88 PA
Drivetrain/Differentials
Jul 24, 2014 05:20 PM
auto_editor
Mar 11, 2014 08:32 AM
1966Oldsmobile
Nov 24, 2013 04:10 PM
