Pinion seal is still leaking 😒
Old Oct 21, 2024 | 09:50 PM
  #41
monzaz's Avatar
Originally Posted by 72455
Ok...so here's where I am. I don't really want to pay the shop to take it apart again, and I don't have a convenient way to do it myself. If I just have a drip or two, and since I've already had the seal replaced, and if I keep an eye on the fluid level, is it really that much of an issue?
Take it back and make them do it again ....or find out what is REALLY LEAKING.... They are the mechanics. Make them ACTUALLY do their job.... Gee...
These mechanics these days just do what you tell them and do not even look for a seal area recessed or many when they installed it the spring popped off the inner lip or like they are say they did not use a Teflon or RTV sealant to the pinion spline to inner yoke spline etc. THERE IS A REASON ... THEY need to find it.
Jim
JD
Old Oct 21, 2024 | 09:53 PM
  #42
monzaz's Avatar
You can also dry the area with brake cleaner and let it sit for a day to see if it might be a seepage issue or a short drive around the block if it does not leak just sitting.
You have to clean everything real dry so you can see where it is happening.
ALL THIS IF YOUR NOT going to take it back to the shop.
Jim
JD
oldsonharmont
Drivetrain/Differentials
Apr 19, 2023 05:04 AM
carnutz
Jun 2, 2022 09:24 AM
hwalzer
Aug 27, 2021 07:33 AM
nonhog
Jul 7, 2011 05:47 PM
