Pattern check
Old Aug 3, 2024 | 06:40 PM
runt's Avatar
Pattern check
This is my first time rebuilding a differential and I’m a bit unsure of the pattern I’ve got. Backlash is between .008 and .009 and I’ve got .030 shims under the pinion bearing, how does my pattern look?
Old Aug 4, 2024 | 07:47 AM
monzaz's Avatar
What is the rear make ?
8.2 8.5 7.5 12 bolt?
It appears to be a runner.
If it feels nice and smooth turning and you have the pinion preload correct and the carrier is TIGHT in the case (meaning you have to pry it out with a crow/j bar to remove from the case ---you are on the right path.
Mix a couple squirts of oil on the ring and send a few more pics.
Jim
JD
Old Aug 4, 2024 | 07:48 AM
monzaz's Avatar
from the housing collar for the axle tube be ing pressed in it looks like a 66 67 10 bolt 8.2 rear
Old Aug 4, 2024 | 08:22 AM
runt's Avatar
nailed it. 66 BOP rear.
Old Aug 4, 2024 | 08:41 AM
runt's Avatar
Jim
JD
what do you mean by a runner? It is smooth and indeed is tight enough that I need a pry bar to remove the carrier.
Old Aug 4, 2024 | 11:39 AM
runt's Avatar
Here’s a few more pics with more paint and some
oil. I know it’s a bit much to paint the whole gear but it was kind of on every tooth anyway so I figured why not.
Old Aug 5, 2024 | 06:37 AM
monzaz's Avatar
'A runner' Meaning run the gear looks good. Shes a runner....
Old Aug 5, 2024 | 06:43 AM
monzaz's Avatar
ok now the first run just do a around the block no more than 5min. run and check for leaks.
1/2 hour shut down.
Then run the gear 10 mins. vary speed no more than 50 mph no big monster climbing of hills. and if you have stick shift NO NO transmission gear slowing down....use your breaks only ...no down shifting...creates even more heat.
get back park for an hour...
do about 4 ot 5 of those 10 min runs with hour shut down and if you have no noise you should be good to pound on it.
I do not think your car is a tower BUT no towing till 500 miles...lol.
Good luck.
Jim
Old Aug 5, 2024 | 06:47 AM
monzaz's Avatar
painting all the gears show if you have any run out in the ring to pinion...It is ok. YOU ARE good in my book. I hate when people only paint 4 -5 teeth...NOT enough to get a good enough idea that the gear is not defective in anyway.
I have a 3.36 gear when YUKON first came out with them and one ring tooth was cut twice and NEVER patterned i went around and around and around...lol. yellow compound never came off the ONE TOOTH... just goes to show.
Jim
JD
Old Aug 5, 2024 | 06:49 AM
monzaz's Avatar
you can also push a rag into the housing to wedge against the ring edge and turn the pinion yoke to recreate move heavy drag to see the pattern better too.
Old Aug 5, 2024 | 11:36 AM
runt's Avatar
Jim thank you so much! I will absolutely heed your advice about breaking the new gears in!
Supernice88
Aug 10, 2024 08:27 AM
Kapos79kutlass
Nov 12, 2023 06:23 PM
CutLS442
Apr 30, 2017 05:47 AM
Inline
Drivetrain/Differentials
15
Dec 16, 2016 06:42 PM
denis
Sep 13, 2007 09:03 PM
