Need posi
Old August 15th, 2011 | 11:18 AM
m455sx's Avatar
Olds Nut
Need posi
Does any one have a posi unit for an olds 12 bolt 323 gear, new or used? Also i have a 12 bolt oldsmobile posi rear w 256 gear can that be used.
Old August 15th, 2011 | 06:31 PM
2blu442's Avatar
If this is for your 1970 its not really a 12 bolt, but a Type O 10 bolt. Chebby has the same number of fasteners on the inspection cover as hold the ring gear on. Olds does not. The Type O was used from 1967 through 1970 and have a limited supply of parts available. I believe Monzaz has reproduced the Type O posi carrier (or more correctly called a limited slip... but same function as the positrac made by other GM manufacturers). I would encourage you to contact him for a new one. He may also have a used or restored one if you can't afford the new one at this time. 507OLDS may be another source for a used or restored one. I think you'll enjoy the difference changing from a 2.56 to a 3.23. Good Luck on your project! John
Old August 15th, 2011 | 07:54 PM
Joffroi's Avatar
Runner
How much does one usually go for. Thinking of upgrading my 68 down the road
Old August 16th, 2011 | 04:38 AM
m455sx's Avatar
Olds Nut
My 442 has a 323 gear, but was ordered with out posi. The 256 came in my SX with posi from factory. The 256 rear in under the bench in my garage as i have installed a 308 posi big 10 bolt in its place. Is Monzaz a company or a person on this site?
Old August 16th, 2011 | 05:29 AM
507OLDS's Avatar
Both Monzaz and myself,have the posi units.I think he might have more in-stock than me right now,as I have a lot of orders for complete rears waiting.The new units will fit the 3:08/3:23 ratios,and will also work with the new Richmond gears.The posi unit in the 2:56 rear will work with 2:56/2:78 ratios.It can be used for the 3:08/3:23 gears,but you will need a spacer.I have a few of those made once in awhile,and Jim(Monzaz) might have some as well.
Old August 16th, 2011 | 05:37 AM
m455sx's Avatar
Olds Nut
send me a price with shipping
Old October 4th, 2011 | 05:38 PM
m455sx's Avatar
Olds Nut
i would like to get a posi for my 323 rear
nj_cutlass72
November 20th, 2019 09:11 PM
2blu442
Drivetrain/Differentials
September 26th, 2009 05:59 PM
69OldsCutlassS
September 9th, 2009 01:05 PM
buzzbomb
January 6th, 2008 09:51 PM
troy1
October 22nd, 2007 09:27 AM
Quick Reply: Need posi
