Gear Ratio Opinions Please
Old Aug 15, 2011 | 04:50 PM
7D2455's Avatar
My '72 currently has the 8.5" 10 bolt open differential with 2.73 gears. Its got a 455 mildly built, a TH400, and I'm running 27" tires in the back. The car never sees the highway, only driven around town for fun.
I just picked up another 10 bolt that has factory posi and 3.23's, as well as an extra set of 3.73's. Do you guys think I should swap in the 3.23 axle or would it be a better choice to pay the money to have the 3.73's setup with the posi?
Old Aug 15, 2011 | 06:14 PM
Indy_68_S's Avatar
My math comes out to about..
3.23 = 2800 RPM @ 70 mph
3.73 = 3250 RPM @ 70 mph
....the 3.73 would definitely be more fun around town.....
Old Aug 15, 2011 | 06:31 PM
Lee_A's Avatar
Can you spin the tires already?
Steeper gears will make your car quicker off the line ONLY if you have traction.
3.73's are just too much. 3.23's are a great gear for most 455's. But if you can light up the 2.73's already, you won't gain anything.
3.23's and go MT drag radials would be fun.
Lee
Old Aug 15, 2011 | 06:44 PM
7D2455's Avatar
I can spin the tires pretty easily, but the tires will still grab. It just depends on how I drive it. I dont know a whole lot about how certain gear ratios will effect a vehicle. I know that the higher numbers are supposed to make more torque, but if you go too far then all you will do is burnouts. So I figured I would ask the experienced guys...
Old Aug 15, 2011 | 07:08 PM
oldzy's Avatar
If I had a torque monster like the 455 and those 2 gear choices... 3.23's easily. Now if I had a 350 (like I do) then it would be the 3.73's.
Old Aug 15, 2011 | 07:12 PM
Lee_A's Avatar
The 3.23 posi will be better than a 2.73 open.
3.73's will be too much.
Lee
Old Aug 15, 2011 | 07:31 PM
7D2455's Avatar
I used to think that 3.73's were always the best, and 4.11's were even better, but I guess that's because thats what everyone around me talked about while growing up as a kid, and thats probably because they all had small block chevys haha. Im glad I could get some input from you guys. I think I might be going with the 3.23's, especially since I can just bolt that axle in and run it with no extra costs.
Old Aug 16, 2011 | 05:41 AM
507OLDS's Avatar
The 3:73 is a popular gear for a street/strip 455.If you do not do any highway driving,I would go with those.They will help get the most out of your engine performance.You will not need any more gear than that though.If your car has AC,then you might want to consider the 3:23's.You could freshen-up the 3:23 rear,try that,and have the 3:73's installed into your existing rear,along with a posi unit.
Old Aug 16, 2011 | 08:13 AM
455man's Avatar
Why would A/C affect your gear choice?
Old Aug 16, 2011 | 08:36 AM
Indy_68_S's Avatar
AFAIK, its so the higher engine RPMs don't over speed the compressor...
Old Aug 16, 2011 | 08:44 AM
Rickman48's Avatar
As a youngster, I also thought 4:11's were better than 3:70's, and when the 3:70's went away, got a 4:11! [yes, early sbc]
Only noticed a difference in high gear, though, with a M-22.
With the torque of the 455, I'd also also choose the 3:23's - 3:73's are a little too much - now 3:42's would be perfect!
Old Aug 16, 2011 | 08:49 AM
455man's Avatar
That was what I was thinking. Thanks.
Old Aug 16, 2011 | 09:11 AM
507OLDS's Avatar
Those cars that came with AC were offered ratios up to 3:42.If a ratio higher than 3:42 was ordered,there were certain warranties voided.
The higher rpms can actually disengage the compressor clutch,so you would not be able to get AC.
Old Aug 16, 2011 | 05:53 PM
7D2455's Avatar
Well luckily mine no longer has a/c.
Old Aug 16, 2011 | 06:31 PM
chrisneu68olds's Avatar
@ Indy_68_S
What formula did you use to calculate this?
Old Aug 17, 2011 | 03:41 PM
BlackGold's Avatar
I'm still convinced that the factory limitation of 3.23 for cars with A/C had more to do with engine cooling than over-spinning the compressor.
Cars with A/C received a heavier-duty cooling system.
Cars with low gears (higher numerically) received a heavier-duty cooling system.
It's simple extrapolation to say that, if either of those options alone warranted the heaviest-duty cooling system offered, then both of them together would require the superdupergonzomotherofall cooling systems.
Of course, the factory didn't know if you live in Death Valley or the Yukon, so in the interest of reducing their warranty costs, they played it safe. Your mileage may vary.
Old Aug 17, 2011 | 05:03 PM
Indy_68_S's Avatar
Originally Posted by chrisneu68olds
@ Indy_68_S
I have a little old standalone app the lets me put in tire size, trans type/ratios, diff ratio, MPH, RPM,etc. You just leave one field blank and it fills it in.
But, there are numerous ones out thar on dat IntarWeb.....
Matter of fact, here's an Olds related one now !
http://tech.oldsgmail.com/axle_RPM.php
Old Aug 17, 2011 | 07:37 PM
507OLDS's Avatar
Blackgold,
Yes,that had something to do with it as well.
Old Aug 25, 2011 | 09:45 AM
7D2455's Avatar
So the 3.23 axle a bought turned out to not be a direct bolt in with my Cutlass Supreme, so I took the gears and posi carrier out of it. In a few weeks I'm going to have the posi put into my current 10 bolt rear end, and I think I'll have them put the 3.73's in rather than the 3.23's.
Old Aug 25, 2011 | 10:03 AM
What brand tires do you run - imma gonna invest in their stock. Lol, great choice if you don't do hwy driving. Are you running a stock torque converter???
Old Aug 25, 2011 | 10:30 AM
507OLDS's Avatar
7D2455,
Was the rear out of a different era of car,like a 73-77?
As long as it is an 8.5" 10-bolt,then you can put the guts into your existing housing.
Old Aug 25, 2011 | 10:33 AM
455man's Avatar
But it has to be the 28 splines to fit the axles right?
Old Aug 25, 2011 | 11:55 AM
507OLDS's Avatar
Yes,any 8.5" 10-bolt from 1971 to 1988,has 28-spline axles.
Old Aug 25, 2011 | 12:06 PM
Run to Rund's Avatar
My Cummins diesel pickup "deserves" the 3.73 ratio it has. Oldsmobiles "deserve" 4.10 at a minimum, lol. Since it isn't a high speed highway cruiser, put some gear into it
Old Aug 25, 2011 | 12:42 PM
455man's Avatar
Except a corvette rearend. Are there any other 8.5 10 bolts that dont have 28 splines?
Old Aug 25, 2011 | 07:24 PM
7D2455's Avatar
It is a stock torque converter and fully stock turbo 400
Old Aug 25, 2011 | 07:28 PM
7D2455's Avatar
7D2455,
Yes, it was out of a '73-up full size buick, and when I bought it I didnt catch that the brackets on it were different. But it is indeed an 8.5" 10 bolt.
I would just transfer everything over to the 10 bolt in my Cutlass, but since I'm going through all this work now I want the 3.73's in it, especially since that's what I wanted in the first place. So rather than attempting to setup the posi and 3.73's in my 10 bolt I will just pay a shop to do it to ensure it is done right.
Old Aug 26, 2011 | 12:04 PM
jonrare's Avatar
I have a 455 with 3.73 gears with 28.5 inch tires and its great on the highway and responsive off the highway
i had 2.73 and its a big difference
Old Aug 26, 2011 | 01:34 PM
My442's Avatar
I run 3.91s
Not fun on the highway, but really fun around town.....
Old Aug 26, 2011 | 08:32 PM
56oldssuper88's Avatar
youngin'
If it were mine I would run 3.73's just for the fun. But 3.23's= lower rpm and better highway cruising. The answers that were figured in that formula mentioned sound about right for that trans and those gears combo.
Old Aug 26, 2011 | 11:30 PM
  #31
oldsonharmont's Avatar
I'm not sure if they'll light up the tires or not, but the 3:08's are supposed to be a nice all around gear set. With your big block they're still liveable on the highway, and you'll get off the line a bit quicker around town.
Old Aug 27, 2011 | 06:32 AM
  #32
joesw31's Avatar
Take that rear and harvest the internals, and find a used GM 3.42 ring and pinion. Again, I would use a 3.42 ratio as that gear would give you great perfomance and streetability.
Old Aug 27, 2011 | 06:49 AM
  #33
Bunser's Avatar
Originally Posted by My442
I run 3.91s
Agreed, but I think I'll try and find a 3:42 ring and pinion to make it bearable on the highway.
Old Aug 28, 2011 | 06:43 PM
  #34
7D2455's Avatar
Well at this point I'm not worried about highway driving. If it does see the highway it wont be very far. Pretty much all driving I do with it is in town. I wanna go with the 3.73's, and then in the future its gonna get a 5 speed.
Old Feb 17, 2023 | 04:24 AM
  #35
BLUZIN's Avatar
That was some time ago! Did you ever put in the 5 speed? I am deciding which gears.
Old Feb 17, 2023 | 03:54 PM
  #36
olds 307 and 403's Avatar
Out of Line, Everytime😉
What trans are you planning on?
Old Feb 18, 2023 | 11:01 AM
  #37
Andy's Avatar
3:23’s buy a 2800 stall coverter, car will roast the tire’s or tire.. thats the best all around ratio for you..
442 Guatemala
Jan 15, 2010 10:43 AM
squirell
Jul 7, 2009 09:01 AM
Maverick
Drivetrain/Differentials
Feb 23, 2008 02:27 AM
jeffs 89 cutlass salon
Aug 21, 2007 07:57 PM
442 Guatemala
Jun 11, 2007 10:19 AM
