Driveshaft question
Old Mar 16, 2025 | 06:54 PM
runt's Avatar
Driveshaft question
I reinstalled my driveshaft on my 66 F-85 today and slid the splined shaft into the transmission housing all the way. Then I went down to the rear end and put the U-bolts in to both the yoke to the differential and when I was finished I noticed the shaft had slid out of the transmission a bit once the U-bolts were tightened. It's seated in there fine, but I'd say there's about an 1" or 1.25" exposed between the dust seal on the transmission housing and the front yoke. Is that ok? I really don't see any other way to install the driveshaft, but I just want to be sure. Stock rear suspension and trans, only thing I changed was the gears inside the rear.
Old Mar 16, 2025 | 06:58 PM
Lonnies Performance's Avatar
That's how it should be. Around 1" of movement is normal.
Old Mar 16, 2025 | 09:05 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Yep...this is correct. If it was up against the seal or bottomed out in the yoke when the car is level the suspension articulation would drive-back on the tail shaft and cause internal trans damage.
Old Mar 17, 2025 | 02:10 AM
runt's Avatar
Thank you both!!!
Old Mar 17, 2025 | 04:21 AM
Keep in mind that with the rear axle hanging down, the yoke is pulled further out of the trans than when the suspension is at ride height.
Old Mar 17, 2025 | 04:55 AM
runt's Avatar
Yes, thanks! I thought about that and didn’t really think anything was amiss until I put the car back on the ground and saw that it still had about an inch exposed.
442operator
Drivetrain/Differentials
Nov 20, 2022 03:04 PM
1967Supreeeme
Aug 14, 2019 11:21 AM
deadeyejedi
Aug 3, 2019 08:31 PM
Toms cutlass
Jun 20, 2017 07:20 AM
Jayycobb
92
Apr 25, 2013 11:21 AM
