Change the original diff fluid?
Old Jul 23, 2014 | 03:31 PM
HiCompOlds's Avatar
Guys...I've been "going through" the different components of my car (engine, trans, brakes, etc.) and I'm wondering if I should open up the rear end and drain out the fluid and replace it with new. My car is a '65 Cutlass with 57,000 miles (and as far as I know and can tell those are original miles). It has the conventional rear with 3.08's. What do you guys recommend...do it or let it be? I keep thinking that the fluid is 49 years old!!!
If I do it, what gear oil should I use?
Thanks.
Old Jul 23, 2014 | 03:40 PM
If its an open rear just plain ol 80/90 wt gear oil. With a posi you will need the additive to go with it. It won't hurt to change the oil if it were original.
Old Jul 23, 2014 | 03:44 PM
starfire's Avatar
I would go ahead and change it. You will probably need a new cover gasket too.
Old Jul 23, 2014 | 04:01 PM
jag1886's Avatar
Yes it should have been change about 20 years ago.
Old Jul 23, 2014 | 06:04 PM
HiCompOlds's Avatar
Thanks for the replies and advice guys...I'll go ahead and change it out.
Old Jul 24, 2014 | 04:26 AM
HiCompOlds's Avatar
One more question...how much gear fluid do I need? I believe it's around 3 pints. Can someone verify so I know how much to buy. Thanks again.
Old Jul 24, 2014 | 09:25 AM
JohnnyBs68S's Avatar
Buy two qts, it'll be enough.
Old Jul 24, 2014 | 11:02 AM
HiCompOlds's Avatar
Ok...thanks.
68oldscutlass
Drivetrain/Differentials
17
Mar 22, 2013 05:37 PM
Nasty455
May 15, 2012 06:04 AM
dre
Aug 31, 2011 11:04 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
