best way to break the pinion nut to replace seal
Old August 15th, 2010, 11:37 PM
1973olds98's Avatar
I just cant seem to break the nut lose to replace the seal,,any suggestions?
1973olds98 is offline
Old August 16th, 2010, 02:03 AM
scrappie's Avatar
Air gun? maybe some careful heat?
scrappie is offline
Old August 17th, 2010, 06:10 AM
507OLDS's Avatar
Is the rear in or out of the car?
507OLDS is offline
Old August 17th, 2010, 11:48 AM
If the rear is in the car, just have someone stand on the brakes while you loosen it. If not, you need to make a tool to hold the pinion. A simple piece of steel bar or angle iron, with two holes to pick up two of the holes in the pinion flange, will work fine. Note that if you are simply replacing the seal and not rebuilding the center section, you need to mark the position of the nut before you remove it. When you reinstall, you need to retorque to that position, then go just a little more to avoid distorting the crush sleeve.
joe_padavano is online now
bob p
June 4th, 2015 01:53 PM
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
defiant1
July 10th, 2011 07:41 PM
jpaulwhite
Ninety-Eight
August 3rd, 2010 08:45 PM
mcutlass1969
Drivetrain/Differentials
August 18th, 2008 09:59 PM
Quick Reply: best way to break the pinion nut to replace seal
