725 Carrier For This Rear End? Just To Make Sure Before Tearing Into It!!
Wanting to convert a 72 442 rear end over to a posi with gear change as well. Car currently has SA 0070 stamped rear end - according to CSM it's a 2.73 open. I have a posi carrier with the "725" numerals cast in it between the ribs. Is this the correct unit to use in this rear end - and will 3.42 gear & pinion bolt on without having to shim? Thanks!!
Yes,the 725 carrier is a 3-series carrier for the 71-up 8.5" 10-bolt.This will take any ratio 2:73 & numerically higher.The 410408N is the more common 3-series carrier for the 8.5" 10-bolt The difference is the 725 has side gears that are NOT machined for c-clips,and the 410408N has side gears that are.Since you are building an 8.5" 10-bolt,for a 71-72 Cutlass/442,you could use either one,since you have bolt-in axles.
Thanks Brian - was hoping you'd answer so I can put this to bed. Let me know if you sell a kit for all the seals, bearings (including wheel bearings) to rebuild the rear end - I've read some of you posts on the junk that's out there.
You can get all of the Timken bearings & seals at AutoZone,with the exception of the axle bearings,as they stopped carrying those about a year ago.Timken still makes them though.Lately,I have found some suppliers on ebay selling them.
Pinion seal # 2043
pinion bearing,outer # M88048
pinion bearing race,outer # M88010
pinion bearing,inner # M802048
pinion bearing race,inner # M802011
carrier bearing # LM501349 (need 2)
carrier bearing race # LM501314 (need 2)
axle bearing # SET9 other brands call it # A9 (need 2)
axle seal # 712146 (need 2) Do NOT cunfuse this with the thinner #2146
Pinion seal # 2043
shamusj
Drivetrain/Differentials
January 14th, 2015 12:34 PM
leepear
October 17th, 2010 08:12 PM
chris83
September 20th, 2010 08:15 AM
