type 'o' SA upgrade
Old Sep 17, 2011 | 02:42 PM
olds1968's Avatar
member
type 'o' SA upgrade
i have the stock 2.78 open diff in my 68 cutlass and i want to add a posi with 3.23-3.73 gears if possible.
Old Sep 17, 2011 | 05:44 PM
rcorrigan5's Avatar
Randy C.
As I understand, you can use your 2.78 open differential (most likely with 28-spline axles) in upgrading to a 3.42 or a 3.91 posi. There are new units on the market with those gear ratios that will fit into your Type "O" differential housing and mate up with the 28-spline axles. Between the two, I'd chose the 3.42:1 posi unit - it's a good mix between performance and getting around on the freeway.
Randy C.
Old Sep 18, 2011 | 08:26 AM
olds1968's Avatar
member
i was able to find a thread that said i needed a spacer to accept the lower gears but no information on who sells these parts.
Old Sep 18, 2011 | 08:47 AM
defiant1's Avatar
I would contact monzaz on this site. I picked up a complete axle housing from him with 3.23 posi (Auburn limited slip).
He also has 3 series posi carriers, if you already have the gears and axles, to fit with your application.
For a comparison, I am pulling 3000 rpm (maybe a hair under) @ 70mph. It still cruises well (not as well as the peg leg 2.56 I had) and definitely launches better.
For my relative mild performance motor and stock torque converter/transmission, it was a nice improvement.
d1
Old Sep 20, 2011 | 04:53 AM
507OLDS's Avatar
If you use the correct carrier,you will not need a spacer.The posi carriers that Monzaz and myself sell,are correct for the Richmond 3:42 & 3:90 gears.They are also correct for the GM 3:08 & 3:23.
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
g77rvd
Jan 9, 2011 06:29 PM
LMHConcepts
Jan 4, 2008 12:55 PM
bcg88
Jul 15, 2007 06:06 PM
sean000
Dec 22, 2006 06:41 PM
