71 cutlass convertible rear end
Old Feb 1, 2014 | 09:56 AM
Danp76's Avatar
Hi guys I have a 71 cutlass with a 350 trans/engine. I'm installing a newly built 455 engine and a turbo 400 trans. I currently have a 10 bolt rear end, can I buy aftermarket kits to make it posi? Can I purchase aftermarket gears to increase my rear end ration? or should I go with a 12-bolt rear?
Old Feb 1, 2014 | 06:51 PM
507OLDS's Avatar
That is a great rear to build. The 71-72 Cutlass/442's came with an 8.5" 10-bolt. There are plenty of parts available for that rear,so you can build it however you want it.
Old Feb 1, 2014 | 07:08 PM
Danp76's Avatar
Thanks for the information 507Olds, is the 10 bolt durable enough to handle my 455/400 trans combo? What gear ratio would you recommend? It's a 71 convertible for cruising. And where can I buy gears/posi parts for this, any recommend brand parts? thank you.
Old Feb 1, 2014 | 07:21 PM
507OLDS's Avatar
Yes. It will be fine with the 455. There are plenty of parts available for that rear. I can supply a kit. I would run a 3:23 or 3:42,for what you want to do with the car.
Old Feb 2, 2014 | 05:02 AM
Danp76's Avatar
Hi 507OLDS, how much would a kit cost to make it posi and change the gear ratio? What brand parts would they be? Thanks, Dan.
rcdynamic88
Drivetrain/Differentials
Apr 7, 2015 11:21 AM
350TurBRO
Sep 12, 2014 11:52 AM
MDchanic
31
Aug 12, 2012 04:24 AM
Nor Cal Andy
Apr 1, 2011 07:13 PM
esisson
Feb 7, 2011 11:34 PM
