Will a GM yoke fit an early BOP - same spline
Old Feb 2, 2014 | 06:23 PM
mr_mahoney's Avatar
Will a late model GM yoke fit an early BOP rearend?
Both 8.2 and 27 spline on pinion shaft.
Data here:
http://www.oldsmobility.com/old/10bolt-tech.htm
I need my early BOP rearend needs to connect to a newer drive shaft with 1/18 bearings. My rearend uses inside clips and can't find a combo ujoint.
Old Feb 2, 2014 | 07:31 PM
coppercutlass's Avatar
Chevy budget Olds powered
I had a driveshaft shop custom make a u joint for a small fee. One side has smaller caps the other had huge caps. I accidentally got shipped a yoke for a serious hp car. Mine was on the trans side but they made it work. Is that what you means by combo u joint ?
Old Feb 2, 2014 | 07:39 PM
archeryshooter's Avatar
Tony
Data here:
Look up Strange contact info they have a website I called them awhile back on my setup and they have a lot of choices and might have the right setup on the shelf for your stuff they were nice to talk too
Old Feb 3, 2014 | 08:05 AM
mr_mahoney's Avatar
Yes, combo ujoint has different size cups. My drive shaft has 1 1/8" cups with inside clips and my rearend yoke has 1 1/16" cups inside clips. I thought I would just swap out yokes on the rearend. Later model 8.2 10 bolt GM rearends have 27 spline as does the early BOP.
I was wondering if this had been done before.
oldzy
Drivetrain/Differentials
17
Jan 23, 2016 09:06 AM
sadisticsavage
Jan 11, 2014 11:06 AM
Seff
Feb 10, 2013 07:51 AM
JCMC64
Jan 23, 2013 05:10 PM
Mechanical Myth
Mar 18, 2012 01:27 PM
