65 rearend fit a 69
Old Apr 16, 2018 | 01:40 PM
78 omega 468's Avatar
65 rearend fit a 69
I have an 65 Malibu SS a oak tree got the front cap and front part of top and windshield. The rearend is a 12 bolt posi trac. Is this a bolt in for a 69 Cutlass S? I have read that it will fit but is a little narrower.
Old Apr 16, 2018 | 06:08 PM
stan 65 cutlass's Avatar
iknow the 65 cutlass is slightly narrower than 66 and on, .625 each side if my memory is correct, but the mounting is the same
Old Apr 16, 2018 | 09:02 PM
Gerald Nickels's Avatar
U joint are different. I had a 70 3.91 W-27 in my 64 Cutlass I raced and bolted in but the pads for the coils are different but worked.
Old Apr 17, 2018 | 07:13 AM
monzaz's Avatar
65 rear into a 69 chassis A-body gm
Yes all 1964-1972 rears can be interchanged between all A-body cars. In this case you will have a narrower 65 housing by 1" over all... so 65 rear is 60" drum to drum and the 69 is 61" drum to drum.
Next the spring perch will be slightly different 65 perch is flat and requires a cup and bolt to hold the bottom of the spring on the persch where as the 69 and all the late 66-72 have a raised perch round 1" ish high by 3" round diameter the spring pig tail will sit around the diameter of this perch.... and the shock length travel will keep the spring from popping up and out.
The last different hurdle is the u-joint from chevy to BOP -
chevy yoke will have the 1 1/16" cup and narrower cross on the u-joint and the BOP is the M3R 1 1/8" cup with a wider cross in the u-joint...a Moog 372 will connect your chevy yoke with your BOP driveshaft.
Jim
J D Race
Old Apr 17, 2018 | 08:52 AM
Thank you that will help a lot. I was also told if all the numbers match for a 1965 SS that it could be worth enough money to put another rearend in the 69. I know I got huge money for the decklid with the ss badging and the badges from the 1/4 panels.
72Cutlass
Drivetrain/Differentials
Apr 18, 2008 09:24 AM
1BAD68"S"
Dec 29, 2007 09:05 PM
Jolly Green
Sep 4, 2007 08:27 AM
66JET
Jan 6, 2007 02:33 PM
