1971 olds 2.56 posi
1971 olds 2.56 posi
I have a 71 cutlass s that has a posi rear end. As far as I know it has about a 256 gear in it. I have gathered a little info and found out that I cannot put different gears on this carrier. Does anyone know if a chevy 10 bolt carrier will work in this rear end? Here in phoenix its possible to get mid to late 80-90 rear ends with 373 posi for what I consider to be reasonable prices 200. Any help would be appreciated.
thanks
Leche
thanks
Leche
Ring gear spacer
Thanks...I am going to look into this. I have never heard of a ring gear space before so this is actually a bit of bright light. It will hopefully make this project a bit easier to complete
thanks again
Leche
thanks again
Leche
Ring gear spacer
I did some looking around on the net...and as usual you really cant find a "definitive" answer....Is there anyone who has tried a ring gear space and not had problems..I would use it with stock engine...no high horsepower etc?
Actually, if you can find "thick" ring gear sets designed for your 2-series carrier, this is structurally a little better than using the spacer. Basically the thicker ring gear has the spacer built in. This keeps the bolts from the carrier to the ring gear in pure shear. The spacer introduces a bending load that can cause bolt failure.
nj_cutlass72
November 20th, 2019 09:11 PM
69OldsCutlassS
Drivetrain/Differentials
September 9th, 2009 01:05 PM
monzaz
March 15th, 2009 04:43 PM
buzzbomb
January 6th, 2008 09:51 PM
