1971 Cutlass Supreme Gear Swap
Old May 14, 2020 | 11:45 AM
delta254's Avatar
Hello everyone I'm looking to swap my gears to 3.73. From what I have gathered and did the spin test I have a 10 bolt 8.5 posi unit with 2.56 gears currenty. I have a LS 5.3 swap with 4L60E trany. My question. I want to buy Richmond Gears 3.73 part # 49-0041-1 will these work with my Carrier or do I need other parts. Or is there another manufacturer that makes 3.73 that work with my current carrier which I don't know what it is..Thank you guys
Old May 14, 2020 | 12:45 PM
There is a footnote on the Richmond Gear page that I suspect you missed:
When replacing a stock 2.56 and numerically lower, the carrier must be replaced with a carrier of 2.73 or higher.
Old May 14, 2020 | 01:03 PM
delta254's Avatar
Oh wow never saw that..So I can get those gear #'s and a new carrier and should be OK?
Old May 14, 2020 | 01:17 PM
Yes. In theory you could also use a ring gear spacer on your existing carrier, but that would not be as strong as using the "correct" series carrier with the ring gear.
Old May 14, 2020 | 01:24 PM
delta254's Avatar
3.73
Will these work with out a new Carrier assuming mine is a 8.5 Axle?
Yukon Gear ZG GM8.5-373
Old May 14, 2020 | 05:36 PM
The US Gear web site doesn't show anything about which carrier they will fit, so my guess would be they are similar to factory gears. This may be why their info shows the carrier breaks below: 2.56 and lower is a 2 series carrier and 2.73 and up is a 3 series carrier. That would mean for their 3.73 gears you would need a 3 series carrier.
Carrier Breaks: 2.56 / 2.73
http://www.usastandardgear.com/diffd...ar+-+28+Spline
Someone out there may make 3.73 gears that fit a 2 series carrier but I don't know about them. I would say check with monzaz as he does this stuff for a living.
Old May 14, 2020 | 06:40 PM
delta254's Avatar
Gears
Ok let me shoot him a message I hear his name mentioned alot in the gear forums...thank you for the help I just want to make sure I purchase the correct stuff and save my self a headache or 2.
Old May 17, 2020 | 09:12 AM
monzaz's Avatar
8.5 info
There are NO thick 8.5 gears like as in the 7.5. GM aftermarket or other wise.
2.73 - 5.57 are all 3 series gears
2.41 - 2.56 are all 2 series gears
there is a 2.24 also we found in a caddilac seville 47 ring and 21 pinion 2.2380952 totally amazed to find this ratio... sold them to the flats guys...
If you are hanging on the street and very little track under 12 sec mark you should be ok with a ring gear spacer Kit ... proper length bolts is the key as this is what makes a ring gear spacer fail. If your spacing .200 more the bolts need to be that much longer too.
We did a test on a 12 bolt Chevy early in the companies beginning to knock all the crazy taboo info about these things in the differential world.
Ring gear spacer was the first one.
We too a 2 series 12 bolt Chevy POSI installed a spacer and 4.10 THICK gears for a 3 series carrier. Installed all that and ran it at the track for years ...on the street burn outs 454 motor beat on it pretty good 4-5 years I think proved that incorrect info. 12.10 with slicks 2500 stall 29" x 9 slicks.
If you are going faster than 12 sec you have invested enough money to make a steel full bodied car you should now invest in correct parts to continue going faster etc.
Installation details really does go far in most application and reason why parts usually fail if NOT defective from the get go.
I am sure SOMEONE will chime in and give guff... this is just our experience with them. You can take or leave this info.
We do understand it can save you money on a complete new posi carrier. Just do not be too cheap if you really can afford to buy better safer parts.
Just trying to give real world info with out bias attitude as much as possible.
Jim
JD
Old May 17, 2020 | 09:33 AM
As always good information and I appreciate you sharing your knowledge and experience with us. I always learn something from your posts.
Old May 17, 2020 | 10:19 AM
delta254's Avatar
Gears
Jim
JD
Thank you sir I will take this info and just have a shop do it..lol..definitely not under 12 car and will not see a track. Thank you guys for the info.
Old May 18, 2020 | 07:00 AM
delta254's Avatar
Id #
I found this number on it 407299 if that helps to know what carrier I have.
Old May 18, 2020 | 08:33 AM
monzaz's Avatar
numbers
CArrier?
That is the casting number of the housing? Y/N?
It will not tell you which carrier you have? 2 or 3 series posi or non posi etc.
or
Am I missing something?
we IDed the rear as a 8.5 GM
Old May 18, 2020 | 09:48 AM
delta254's Avatar
Casting
CArrier?
or
Yes sorry that's the housing #..Both tires turned the same direction so I'm sure that's POSI but I could not calculate my gear ratio I came up with 3 or so..I do know my RPM stay pretty Low on the hiway.
Schne442
Drivetrain/Differentials
Dec 15, 2019 08:03 AM
RustRocket
Sep 4, 2014 11:46 AM
cutlassclay
Feb 18, 2014 08:56 AM
devmar07
May 2, 2013 09:34 PM
LIMEGREEN71
Feb 22, 2010 03:45 AM
