Gear Swap for an 82
Old Sep 4, 2014 | 09:09 AM
RustRocket's Avatar
Gear Swap for an 82
I have an 82 Cutlass 3.8, and i was wondering if the 3.42 Posi gears from my brother's 86 IROC-Z28 would swap in. Also, I heard the 1982 V6's had a 3.08 rear end from stock, Is this true? Any feedback is great, Thanks
Old Sep 4, 2014 | 11:46 AM
monzaz's Avatar
gear swap
Yes the 1986 10 bolt 7.5 posi and gears will swap into your g-body 7.5 rear. YOU DO need to reset all the backlash and pinion depth... It is not just like bolting on a door handle or something...lol.
3.08 gears. 231 can come with any ratio more likely they came with 2.29 2.41 etc. torquey motor will get the crappy gears and the motors that are gut-less got the steeper gears to get them moving.
The Irocs normally came with 9bolt Aussie rears. Be careful and ID that rear before assuming it is the same rear. Jim
JD
coppercutlass
Drivetrain/Differentials
22
Mar 14, 2014 07:14 PM
cutlassclay
Feb 18, 2014 08:56 AM
jcl
Sep 18, 2013 12:51 PM
devmar07
May 2, 2013 09:34 PM
drjr56
Sep 9, 2012 08:05 PM
