1966 Holiday Cutlass 12 Bolt....Need Some Info
Howdy fellas,
I have some misinformation. I defintalely has a 12 bolt under my 53,800 mile Cutlass and I was told many years ago it was a O code however I was replied to here saying that it prolly was NOT a O Type. So, I am out scraping crude off the diff trying to find some codes.
Can someone link me to a list of numbers and where to look? I know where to look for the 67-70 O Type but that is it.
BTW my car was built the 4th week of July 1966.
Thanks,
(pics to come soon, having camera issues)
Thanks,
One of the easy ways to verify an O-Type is to pull the cover and see if it has 10 bolts holding the ring gear on.
I did find these pics of the O-Type 12 bolt and the Chevy 12 bolt covers. you can see there is a very definite difference between the O-Type on the left and the Chevy 12 bolt on the right.
![](http://www.drivetrainshop.com/v/vspfiles/assets/images/axle_gm_12bolt_2.jpg)
I found this on Supercars Unlimited's web site showing the difference in the covers:
![](http://www.jdrace.com/diff_id/12b84/12bolds3.jpg)
That stamp will just be the gear code. If you're wanting to determine what make rear it is you will need the casting code off the center section.
Gear code stamp on tube from a couple of my O-Type 12 bolts:
Standard 2.56 open
Optional HD 31 spline 3.42 open
Standard 2.56 open
sx455raidercelticfan
August 1st, 2010 08:03 PM
pontchief
20
May 8th, 2007 05:06 PM
