12 bolt O-type ring gear spacer???
Old September 7th, 2016, 07:24 PM
442mark's Avatar
I just picked up a 2.56 Olds posi rear (12 bolt cover/10 bolt ring gear) out of a 1970 Vista Cruiser. I'm wondering if there is a ring gear spacer available out there that would allow the use of a new aftermarket O-type 3.42 ring & pinion set with the factory 2 series carrier (#673) that this rear has? Would a widely available corporate 10 bolt spacer work or is this a custom fab job to make it happen? Thanks in advance.
Mark
442mark is offline
Old September 7th, 2016, 10:28 PM
orange442's Avatar
It would be custom I believe. Brian Trick (507Olds) or Monzaz on this site would know, they are the go to guys for this stuff!
orange442 is offline
Old September 8th, 2016, 08:59 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
I was able to get one from Drive Train Direct or National Drive Train 15 years ago so memories clouded. They all insisted I was looking for an 8.2" but I insisted it was 8.5 and they did search further to find the 8.5 type O I needed. Mr Gasket I believe?
I used a 256 geared limited slip carrier asm and fit the original to 308 to it, which isnt to bad of a stretch. But going to a 342 makes for a thick spacer. It should still be doable with longer ring gear bolts of course. A custom spacer isnt hard to make and shouldn't be to crazy on cost. Be sure you use ARP bolts and washers to bolt it up.
Now you have to decide if its a O type or a Corporate? Not sure on the 70 wagons and or if they got both rears (early & late production cars). Worst case is someone can take a mic and calipers to the assembly and whittle the proper dimensioned spacer with the right measurements.
When you do find the right answers circle back here.
droldsmorland is offline
Old September 8th, 2016, 04:53 PM
oldsmobiledave's Avatar
Fyi
No Corporate 8.5" until 1971 model year. If it is a 1970 model it is a Type O differential.
oldsmobiledave is offline
Old September 8th, 2016, 05:34 PM
Brian was advertising O-Type spacers a couple years ago so he may still have some in stock.
Fun71 is offline
Old September 9th, 2016, 12:23 AM
442mark's Avatar
Great info guys, thanks! I will post what I find out on this end after checking around.
442mark is offline
Old September 9th, 2016, 07:14 AM
alternative
Another easy option is to offer up the 2.56/2.78 carrier for sale & use the money toward a modified 8.8" Ford carrier from Jim @ JD race. He can sell you everything you need to do it once & do it right. Why mess with a 45 year old posi carrier when you can have new?
Old September 12th, 2016, 03:50 AM
monzaz's Avatar
Spacer for 12 bolt O type
I can still make the 'O' type spacers. I use to keep them on the shelf before the 3 series was more readily available from our own stock.
Shot a PM over I can give you some options on reconditioned units too. Jim
J D
monzaz is offline
Old September 12th, 2016, 02:26 PM
Oldsx's Avatar
J D
PM sent
Oldsx is offline
Old September 12th, 2016, 05:09 PM
442mark's Avatar
J D
Jim - pm sent.
442mark is offline
Old October 1st, 2016, 02:04 PM
442mark's Avatar
Jim (monzaz) hooked me up with a custom spacer & bolts in record time & at a fair price.
Great advice, excellent service, way to do business, thanks!!
442mark is offline
Old October 11th, 2016, 09:21 AM
car guy
gearheads78's Avatar
Anyone have a number for Monzaz? I need to order a spacer ASAP
gearheads78 is offline
Old October 11th, 2016, 09:27 AM
PM sent
oldcutlass is offline
Old October 11th, 2016, 09:32 AM
car guy
Thanks Eric!
mauricer
July 10th, 2016 08:58 AM
David DeCan
January 5th, 2016 10:50 AM
Legos
Drivetrain/Differentials
February 19th, 2015 05:43 PM
oldspackrat
August 10th, 2014 10:03 PM
Edveen
July 22nd, 2006 12:15 AM
Quick Reply: 12 bolt O-type ring gear spacer???
