will this manifold work for my 350 rocket
Old July 26th, 2014, 06:36 PM
olds408's Avatar
Need to know if the edelbrock Part numer 27013 Manifold work on my 350 olds engine
olds408 is offline
Old July 26th, 2014, 09:32 PM
White_Knuckles's Avatar
What year 350? If older than 1977 it won't fit according to Jegs. See if your thermostat housing has an external 3/4" curved pipe going down to the water pump? If so, you'll need a 7111 Performer RPM.
White_Knuckles is offline
Old July 26th, 2014, 09:55 PM
White Knuckles, the reason for the "1977" note is the 27013 intake manifold is for a Chevy engine. GM used various makes engines starting in 1977.
olds408, you need a Performer 350 Olds (2711 non-EGR or 3711 EGR) or a Performer RPM Olds (7111).
Fun71 is offline
Old July 27th, 2014, 09:07 AM
This is the manifold you asked about:
This is an Oldsmobile mainfold:
What do you think?
joe_padavano is offline
Old July 27th, 2014, 09:48 AM
Old School Olds
tru-blue 442's Avatar
Here's one that will work
for $60, plus the ship.
A little heavier though.
tru-blue 442 is offline
Old July 27th, 2014, 11:12 AM
Octania's Avatar
I think it's retarded to put the distributor thru the intake manifold
I think it's retarded to force the distributor gear UP against the distributor which has been located by... the intake manifold which has been located by the heads and gaskets and all the machine work done to THEM....
Octania is offline
Old July 27th, 2014, 02:43 PM
Originally Posted by Octania
...located by... the intake manifold which has been located by the heads and gaskets and all the machine work done to THEM....
Yeah, but at least the intake sealing surfaces aren't at right angles to the deck...
Wouldn't want to make calculating the amount to mill for fitment easy or anything.
Old August 6th, 2014, 05:38 PM
captjim's Avatar
You know, in all my years I never even thought about that..... Good point, another reason not to go Chebby!
captjim is offline
yeahbuddy
March 12th, 2016 12:29 PM
smkn600ctd
December 29th, 2014 05:38 PM
olds408
August 6th, 2014 05:35 PM
CyberCholo
April 12th, 2014 12:38 PM
xerxes600rr
February 6th, 2010 01:11 AM
Quick Reply: will this manifold work for my 350 rocket
