will this manifold work for my 350 rocket
What year 350? If older than 1977 it won't fit according to Jegs. See if your thermostat housing has an external 3/4" curved pipe going down to the water pump? If so, you'll need a 7111 Performer RPM.
White Knuckles, the reason for the "1977" note is the 27013 intake manifold is for a Chevy engine. GM used various makes engines starting in 1977.
olds408, you need a Performer 350 Olds (2711 non-EGR or 3711 EGR) or a Performer RPM Olds (7111).
I think it's retarded to put the distributor thru the intake manifold
I think it's retarded to force the distributor gear UP against the distributor which has been located by... the intake manifold which has been located by the heads and gaskets and all the machine work done to THEM....
Wouldn't want to make calculating the amount to mill for fitment easy or anything.
yeahbuddy
Mar 12, 2016 12:29 PM
smkn600ctd
Dec 29, 2014 05:38 PM
CyberCholo
Apr 12, 2014 12:38 PM
