Tune Up
Old Dec 22, 2010 | 08:42 AM
zates's Avatar
Peter
Tune Up
Just installed new cap, rotor, wires and plugs in a stock 350 (76). Haven't set the timing as of yet, but attempted not to move the rotor when installing it. I have a definite misfire with a bit of engine knock now. Before the install there was no noise or miss. Could this be a timing issue? Or something else? Thanks for the help.
Old Dec 22, 2010 | 08:52 AM
slowolds's Avatar
Loose Radical
re-check your wires for firing order.
Old Dec 22, 2010 | 09:07 AM
zates's Avatar
Peter
Already did that, and they're okay. Just wondering whether timing is the kicker. If not, I guess I'll have to pull the new cap.
Old Dec 22, 2010 | 12:20 PM
Rickman48's Avatar
Could be the timing, if that cap is off a few degrees. Aftermarket caps aren't known for their quaity control!
Check the timing, first!
Old Dec 22, 2010 | 06:03 PM
MHENDERSON's Avatar
Make sure some one did'nt put the dist in wrong happen to me with my Dodge pick up it was 180 out!I pulled all the wires put it back stock and it did that.
Old Dec 22, 2010 | 06:40 PM
There is no way that you could have changed the timing settings by doing what you did,
HOWEVER, if the cap was made wrong (as above), or if it wasn't seated properly when you reinstalled it, you could be off a few degrees.
Also, if the last guy to tune it up left the distributor clamp bolt just a little bit loose, then you could have moved the distributor a few degrees when you changed the cap.
I'd say go rattle everything around, then put a timing light on her and double check.
Old Dec 23, 2010 | 03:37 PM
Just a shot in the dark, did you gap your plugs and make sure all the wires were secure properly?
Old Dec 23, 2010 | 04:11 PM
coltsneckbob's Avatar
Are u getting these symptoms while at idle or driving? The misfire makes me think you might have distrubed the points....recheck and regap.
Old Jan 30, 2011 | 02:09 PM
zates's Avatar
Peter
Thanks for all of the advice. I pulled and reseated the cap, and she runs fine. It's been awhile since I've done some of this work. Glad there's advice available. Much obliged!
Old Jan 31, 2011 | 12:13 PM
After you set the timing make sure you set your idle mixture screws and your idle speed. A tune up isn't complete until you adjust your carburetor.
Old Feb 23, 2011 | 01:14 PM
blueRAYwhale's Avatar
Smile i too have a '76
on the underside of the HEI distrb. cap there is a small square thing that fits into a small notch in the distrb. housing. i think they(GM guys), did that for indexing the #1 cyl., maybe it's a reference or something. i'd make sure the cap is on correctly and down in that notch because it is possible to put it all back together with it slightly rotated one way or another.
csouth
May 28, 2009 04:46 AM
Brizio
Feb 15, 2009 11:52 AM
gypsy66delta
Aug 19, 2008 12:54 PM
southcarolina803
Jul 8, 2008 07:37 PM
RussTad
Sep 14, 2006 04:09 PM
